good example of linear buckling
Hi, all
Would you please let me know the simple example of linear buckling?
Thank you
4 Replies Last Post 2011/02/21 21:36 GMT-5
Posted: 1 decade ago 2011/02/18 7:54 GMT-5
have you checked the elbow bracket example of the model library Tutorial models ?
Hi have you checked the elbow bracket example of the model library Tutorial models ? -- Good luck Ivar
Posted: 1 decade ago 2011/02/20 21:59 GMT-5
Hi, Ivar,
File-> Open Model library -> COMSOL Multiphysics->Tutorial Models
Is this right?
If it is, I don't have the elbow bracket example even though I search it.
Also, I checked model library update.
However, It doesn't include the elbow bracket example.
Where can I find it?
Additionally, I'd like to download "smeug.pdf"
Where can I download it?
Thank you
Hi, Ivar, File-> Open Model library -> COMSOL Multiphysics->Tutorial Models Is this right? If it is, I don't have the elbow bracket example even though I search it. Also, I checked model library update. However, It doesn't include the elbow bracket example. Where can I find it? Additionally, I'd like to download "smeug.pdf" Where can I download it? Thank you
Posted: 1 decade ago 2011/02/21 1:28 GMT-5
in v4 you can update your library "on line" COMSOL is adding new examples regularly, try a Options Model Library update - Download all, and check again
For older versions you are the best contacting your local COMSOL rep, he can probably find the good version, but I expect that the 4.2 doc, probably coming in a month or two will be even better than the old 3.5 doc, I find already the 4.1 doc nicer for many chapters than the old one
Hi in v4 you can update your library "on line" COMSOL is adding new examples regularly, try a Options Model Library update - Download all, and check again For older versions you are the best contacting your local COMSOL rep, he can probably find the good version, but I expect that the 4.2 doc, probably coming in a month or two will be even better than the old 3.5 doc, I find already the 4.1 doc nicer for many chapters than the old one -- Good luck Ivar
Posted: 1 decade ago 2011/02/21 21:36 GMT-5
I finished the update.
However, that model is not offered.
Do I download it manually?
I finished the update. However, that model is not offered. Do I download it manually?
