2011/02/18 10:22 GMT-5
Have you tried to interpolate on a list of numerical data with a function ?
2011/02/20 12:20 GMT-5
dear Ivar,
thanks for your advice, i've done two interpolation functions and they seem to be working.
however there seems to be a problem, it used to take abt 10mins to run a simulation and now it's taking hours if not days, ( it's actually still running at this very moment ), is this normal ??
thanks so much !
Spencer
[QUOTE]
[/QUOTE]
dear Ivar,
thanks so much !
Spencer
2011/02/20 12:48 GMT-5
could be, but it is really difficult to say like that. Normally if you replace a constant material parameter by a temperature or pressure dependent one, and that T and/or p are part of you simulation you are getting a non-linear probelem, that might need to iterate several times to find a valid solution.
So you must check the convergence of the solver, often following the results with a probe or a useful plot helps to identify if the system converges or are just running away.
It is clear that a few hours running, in blind, is not very encourraging. You might STOP the solver look at th results and RESTART from current location. This might also help the convergence, some times
2011/02/21 18:06 GMT-5
did you try the if operator?
you could define Cp as a variable:
Expression: if(T<400,Cp1,Cp2)
Expression: if(T
