Diffusion of liquid to solid
Does anybody can help me about modeling of Diffusion fro mliquid to solid. I am beginner and I want to know about this and really need help
1 Reply Last Post 2017/10/27 21:40 JST
Posted: 8 years ago 2017/10/27 21:40 JST
You can use the transport of diluted species module, there you can specify the diffusion coefficient of your material (and convection if there is any) and also add you boundary conditions depending on the fluid you have. Basically you have to set the concentration on each boundary. For example if you have water, the boundary conditions will be the concentration of the saturated pressure.
Hi You can use the transport of diluted species module, there you can specify the diffusion coefficient of your material (and convection if there is any) and also add you boundary conditions depending on the fluid you have. Basically you have to set the concentration on each boundary. For example if you have water, the boundary conditions will be the concentration of the saturated pressure. Good luck
