2011/03/28 12:25 GMT-4
Maybe I misunderstand you, do you want to import the interpolation to create a model geometry or?
To me, the interpolation function make it possible to assign material properties dependent on spatial coordinates, not aware that it's possible to use this to create model geometry.
Also, have you checked "Use space coordinates as arguments"? It's important to checked this option if you want the interpolation to be spatial coordinate dependent.
Hope this helps.
XLi
Hope this helps.
XLi
2011/03/28 12:42 GMT-4
Hi Li
Since I have a few .txt or .xls or .csv files with field x,y,z data, I would like to import straight away into COMSOL to build a basic model, which consists of 7 geological layers. I was once advised to use a 'function' to do so, maybe I was wrong to use 'Interpolation', what do you think?
Thanks a lot for your ideas!
regards
Liwah
Hi Li
regards
Liwah
2011/03/29 0:43 GMT-4
search the forum, there is a tread giving an example for v4
2011/03/29 7:49 GMT-4
Hi Ivar
I have been looking through lotsa topics in the forum and couldnt find any, so I posted my question here (sorry if I duplicate the same issue), do you have an idea where is the relevant topic?
Appreciate a lot for your help!
regards
Liwah
Hi Ivar
regards
Liwah
2011/03/29 8:15 GMT-4
Do you think you can import the data as mesh?
It's possible to use Nastran file format to import into Comsol as mesh.
Then you just need to change your txt data according to the nastran format.
XLi
XLi
2011/03/29 15:46 GMT-4
as often I would say yes and now, you need to convert your imported mesh back to a geometry which is not always trivial
try a search for
geom_from_file_test_with_classeur1.txt.mph
try a search for
2012/01/09 3:37 GMT-5
Hi Liwah,
have you solved this problem? Recently, I encountered the similar problem. through with the help of the example "geom_from_file_test_with_classeur1.txt.mph ", I have not solved the problem using the so-called Parametric Curve to build the geometry in the Geometry node. Could you do me a favor to give me some help and guidance? Thanks sincerely in advance.
Best wishes to you and your family.
Hi people
Well, I created a 3D block, and then I tried to import a .csv or .txt x,y,z coordinates file via Interpolation function, to plot geological layers in the block, but to no avail, and here are my questions:
1 - according to Dynamic Help -> Defining an Interpolation Function, I should be able to import a .csv or a .xls file, but obviously I can only choose .txt file under 'Data Source -> File'
2 - under 'Data Format', I choose 'Spreadsheet' because it seems to be the easiest way
3 - under 'Number of Arguments', I put '2' if I have only x,y,z and '3' if I have x,y,z,c (c has the same value as z)
4 - under 'Function', I tried out different function name, i.e. coorfun, cofun...
Question: how many function I should give if I only have x,y,z, only ONE or THREE?
Question: the 'Position in File' is kind of confusing, in my case, I always had the same x,y for all 7 geological layers, but z is different
5 - under 'Interpolation', I choose 'Linear'
6 - under 'Extrapolation', I choose 'Constant'
I always got the same error message 'The file does not contain a valid interpolation function', what is wrong? is there a standard function name? should I choose different 'Data Format'? should I amend all my coordinates files? etc? or I should not create a block beforehand?
Kindly advise. Many thanks for your time!!
regards
Liwah
Hi Liwah,
[QUOTE]
Hi people
regards
Liwah
[/QUOTE]
2012/01/09 3:48 GMT-5
Hi Simon
ended up I created the 3D geometry from scratch, for the reason: a direct import creates a complicated 3D geometry that COMSOL 4.0 couldnt handle i.e. incompatible relative repair tolerance (which leads to a failure of finalization).
up to now, my latest 3D geometry consists of 9 3D geological layers, 4 2D fractures and 2 1D wells, and only with some workarounds, it is postprocessed successfully, else it returns errors anyway.
I will upgrade my COMSOL to latest version sooner or later and see if things work better then. :) good luck!
best regards
Liwah
Hi Simon
best regards
Liwah
