2011/05/24 23:34 JST
I cannot find back the equation just like that and just now but you have all ingrediants in COMSOl, in "solid" the small deformation angle Thx = 0.5*solid.curlUX, etc, also the the uX,uY,uZ, vX,VY,Vz etc
Pls report back, that is one of these formulas I regularly need, but alwys have to rebuild ;) It wuld be nice to have it on clear here on the Forum
2012/02/29 17:41 JST
Dear Ivar,
I would like to compute the curvature as well. Using shell elements, this worked fine. However, in the solid mechanics module I do have problems computing the curvature. What way did you go to get the curvature of the boundary of a solid?
(Did you introduce variables that are only defined on the surface/boundary of a solid domain?) One point I struggle is that using uX etc. only gives the deformation curvature and in my case was zero in the initial state despite the initial state is a sphere.
Kind regards,
Stefan
Dear Ivar,
Kind regards,
Stefan
2012/02/29 18:36 JST
Pertinent question/remark, there is the way I have posted on the Model Exchange, with the Zernike polynomials, you can reduce the optimising to the "z20" = piston, tip, tilt, and sphericity. But Zernike polynomials are only normalised correctly on round circular shapes (use mostly in optics for mirror deformations andeer mounting or gravity load)
there is also the thread, still unanswered, of
www.comsol.eu/community/forums/general/thread/26075/
I must say I have started a few times, normally we have all info with the normals etc in COMSOL, it's just that I have never had the time to finish it up.
The uY-vX ... gives the (small) deformation angles not really the curvature (you need the second order derivatives Iif I remember right
http://www.comsol.eu/community/forums/general/thread/26075/
2012/02/29 23:31 JST
Maybe this link can help:
www.intmath.com/applications-differentiation/8-radius-curvature.php
With that equation you should be able to create a global equation in your solver?
http://www.intmath.com/applications-differentiation/8-radius-curvature.php
2012/03/01 0:55 JST
HI
Yes the equation of the curvature of a line is well known, now express that simply for any portion of a boundary (surface or edge 3D resp. 2D) from the COMSOL FEM internal variables is where I have failed so far
Indeed it looks simple and trivial, so I must have missed something so far ;)
HI
2012/03/01 23:57 JST
Dear colleagues,
since using uX, p(n,x) and ptang(x,x) didn't worked that fine for me I asked the support. There are normal derivatives already implemented. nxcTy for solids or shell.anxty for shells gives the derivation of the surface normal. The mean curvature then is the trace of that matrix elements: (nxcTx+nycTy+nzcTz) gives the mean curvature (or shell.anxTx+shell.anyTy+shell.anzTz) of my surface.
Thank you for your help and your explanations!
Kind regards,
Stefan Wolf
Dear colleagues,
Kind regards,
Stefan Wolf
2012/03/02 0:17 JST
thanks for the feed back, remains for me to dig into the 3D once, still ;)
