2011/12/14 13:09 GMT-5
it has been discussed a few times, if your small geometry is smaller than 1:10'000 or there-about you need to split your domains to respect this ratio, it comes from the difficulty to mesh such dimensional changes
And start manually with the small part and go step by step outwards, while you increase the mesh size as fast a possible, but still respecting your expected gradients and related mesh sizes for the final solution
2011/12/17 8:32 GMT-5
Hey Thanks for the answer!
Yes i know that this issue is very common. I have tried what you suggested but the problem is that i have only one subdomain that i cannot mesh.
Is it possible to divide the domain in smaller just for the mesh without affecting the geometry of the problem?
thanks
thanks
2011/12/17 10:14 GMT-5
Certainly you can cut you domain with a few lines to make several domains and mesh the surfaces separately, but you can also mesh one or two edes i.e. with an exp separation and then mesh the domain. In v4 you have layers to add separations
2011/12/17 13:44 GMT-5
How can i cut a domain in smaller subdomains in 3D geometry. Is there an option for drawing a plane surface?
2011/12/18 5:19 GMT-5
If you superpose 3 bloks of different length you will get the 3 domains, formed as an union of all 3 items, then you can select each individual (intersection parts)
2011/12/22 18:20 GMT-5
thanks, it helped a lot
