disk error while writing temporary solution
I have solved a model on supercomputer and trying to load that file on my pc the size of the file is 44GB, and it doesnt open on my pc instead says disk error while writing temporary solution, how do I resolve this, should i change the directory for comsol?
Rabia
1 Reply Last Post 2012/02/01 12:40 GMT-5
Posted: 1 decade ago 2012/02/01 12:40 GMT-5
if your compressed file is 44Gb, then the GUI would probably need 2x that in RAM and about the same in spare disk capacity (fair guess) which means you need a damn big PC to load that result file.
If it ran on a cluster you probably need to display it on something similar
Hi if your compressed file is 44Gb, then the GUI would probably need 2x that in RAM and about the same in spare disk capacity (fair guess) which means you need a damn big PC to load that result file. If it ran on a cluster you probably need to display it on something similar -- Good luck Ivar
