Are constraints always global?
Posted 2012/03/02 12:32 GMT-5 Studies & Solvers Version 3.5a 3 Replies
Here's a strange problem...
For a supposed one-way coupling model, variable Hz from Module1 is used as the input for Module2. There should be no backward coupling. In Module2 I have a constraint for dependent variable of Module2 on boundary including Hz. When solving the model in two steps, even I only solve Module1 by sequence, the results are influenced by the constraint in Module2, that is, the constraint is seen as global and solved as well.
To get rid of the influence of the constraint on Hz, I turned off the constraint when solving the first step. In the second step I turn it on and solve only Module2. Surprisingly, the results of Hz from the first step solution is even changed by the second step...
Now that the constraint is global, is there any way I can realize a constraint locally in Module2?
Thanks a lot!
Thanks a lot!
3 Replies Last Post 2012/03/03 11:31 GMT-5
