Problem with Accurate flux integration using Darcy's law module
Posted 2010/01/25 3:25 GMT-5 0 Replies
I have a problem about "Computing Accurate Fluxes" using Darcy's law module. According to the help document "Computing Accurate Fluxes", I used the "reacf(u)" way and integrate on the boundaries.
Attached is a simple model to illustrate my problem.
A rectangular geometry, three boundaries are set to Pressure "P0 = 0", while the right side boudary is set to "Zero flux/Symmetry".
If we check the model, first integrate the source term "Qs = 1" in the subdomain,
Result: Value of integral: 1 [m^2], Expression: 1, Subdomain: all the value is "1".
Integrate "reacf(p)" for all the boundaries,
Result: Value of sum: -1, Expression: reacf(p), Boundaries: all
Which means that the total source term integration in the subdomain equals the flowout flux. There is no problem to this step.
My problem is: When integrate only the zeroflux boudary "4", shouldn't be zero. But the results is not zero.
Value of sum: -0.010335, Expression: reacf(p), Boundary: 4
Could someone help me to explain the reason? Thanks a lot in advance.
Hello Xiaogai Li
