Recovery files, Methodcalls
Posted 2021/11/05 10:31 GMT-4 Cluster & Cloud Computing 0 Replies
Does someone know how to recover and continue files which use methodcalls?
I use comsol on a linux cluster in batch mode. There I run a method to start the simulation and export data after solving (with "-methodcall myMethod", see file test.txt). I got the error message "Continue is not supported by method calls" when I wanted to recover a job with "comsol batch -inputfile ... -recover -continue -methodcall myMethod -outputfile ...." .
When I use only "-recover -continue" (without -methodcall) the simulation continues and finished successfully from the last solved timestep on. The rest of the method unfortunately is not run, e.g. to export data. Is there a better way to continue such files (and continue the method)?
Thanks!
Best, Noëlle
Hello Noelle Harte
