2012/10/11 1:28 GMT-4
I can propose, once you have drawn your geometry and defined some physics + loaded at least the initial conditions to populate the FEM matrices (and allow you to do postprocessing) then you can select the domain (2D-axi surface) you consider, and integrate it with a surface integration, while you turn on the "2D-axi volumetric function which simply, implicitely multiplies the operand by 2*pi*r the loop length. You can then add a bolean function to your operand defining the height, such as *(z<H) where H is your height, defined in the correct coordinate frame (with the correct z0 initial height).
If you need to use these variables in the solution (and not only the postprocessing) you need to define the integration in the top Definition node, and define the olume as a variable in the same Definitions but under Variables node
In V4.3 we have now a series of new functions/operators, check the help, so you can perhaps also define the integration directly
2012/10/11 5:15 GMT-4
Hi Dear Ivar,
Thanks for your comment. I will try to define the bolean operator. I think it helps a lot. I need these variables in the solution (so I defined integrations in the top Definition node.
I am working in Max Planck institute for polymerforsschung and we have a network license so it takes a while until I can have access to comsol multiphysics version 4.3.a. I hope I can do that in version 4.3 :).
Viele Gruesse,
Marjan
Hi Dear Ivar,
Viele Gruesse,
Marjan
2012/10/11 10:22 GMT-4
no problem, that was possible even back in 3.3 ;)
