Conjugate Heat Transfer
David Fernandez Bosman
Hello everybody,
I'm simulating the heat transfer on a detector connected to and cooling of a set of detectors connected to some chips that are heating. I'm doing my project in 2-dimentions in order to avoid computational cost. I have my geometry, let's say in the x-y plane.
I'm using the Conjugate Heat Transfer Module because I want to simulate
the cooling effect of forced air moving. The problem is that I would like to simulate air moving in the z-direction. It is possible?
Thank you very much,
David
2 Replies Last Post 2014/05/21 5:27 JST
Posted: 1 decade ago 2014/05/21 0:07 JST
Hi David,
You can only leave out the z-dimension if everything is the same in the z-direction. If the temperature of the flowing air changes in the z-direction I think you have no choice but to make the whole model 3D.
Hi David, You can only leave out the z-dimension if everything is the same in the z-direction. If the temperature of the flowing air changes in the z-direction I think you have no choice but to make the whole model 3D.
Posted: 1 decade ago 2014/05/21 5:27 JST
Thank you Pieter.
I understand what you say, I will have to rethink my problem,
David
Thank you Pieter. I understand what you say, I will have to rethink my problem, David
