Thermocouple model
I am trying to model the effect of two metals that are in contact with a heat source at one end and isolated from each other at the other end. It should be similar to the Seebeck effect in thermocouples. I am trying to obtain the voltage difference produced between the two metals when they both come in contact with a heat source.
Does anyone have any ideas on how to obtain this?
The only info I found was that it is necesary to use the PDE Application Mode.
Any help is appreciated.
Thank you
2 Replies Last Post 2017/09/06 18:02 GMT-4
Hello Gabriela H
Posted: 8 years ago 2017/08/21 12:22 GMT-4
Any success?
I'm dealing with almost same problem that I need to simulate. If you already found out how to do it, please let me know.
Sincerely,
Hi, Any success? I'm dealing with almost same problem that I need to simulate. If you already found out how to do it, please let me know. Sincerely,
Jeff Hiller COMSOL Employee
Posted: 8 years ago 2017/09/06 18:02 GMT-4
Updated: 8 years ago 2017/09/07 8:32 GMT-4
The thermoelectric effect coupling between the electric currents equation and the heat transfer in solids equation is available in the Heat Transfer Module, see www.comsol.com/heat-transfer-module .
You will find a couple of tutorials here:
www.comsol.com/models?q=thermoelectric
The thermoelectric effect coupling between the electric currents equation and the heat transfer in solids equation is available in the Heat Transfer Module, see https://www.comsol.com/heat-transfer-module . You will find a couple of tutorials here: https://www.comsol.com/models?q=thermoelectric Best, Jeff
