Heating due to shear and compressional wave absorption
Posted 2016/01/22 12:35 GMT-5 Acoustics & Vibrations, Heat Transfer & Phase Change, Studies & Solvers Version 5.2 0 Replies
if i suppress streamline stabilization the problem appears through:
(comp1.ht.hs1.Q*test(comp1.T)*comp1.ht.d)*(dvol_spatial)
there is no difference between specifying the source term in the material or spatial frame or including a moving mesh to couple between the two. Nor is there any difference between manually specifying the source term or allowing comsol to determine it automatically. I know the source term is well defined everywhere on my domains.
there is no problem doing the analogous problem in the fluid domain using I_rms*alpha1
any ideas where the problem may be? I can't find any examples of this type, nor a description of lambda, so all suggestions would be welcome!
Hello djps
