Selecting geometary objecs inside another object
hi,
For v4 RF, if a boundary of an object inside another object is to be selected, the one way that I know is from selection list. Is there any possibility to select it with graphical interface, by mouse click.
Irfan
7 Replies Last Post 2016/01/06 9:54 GMT-5
Posted: 2 decades ago 2010/10/14 18:18 GMT-4
ave you tried to click several tims, normally you cycle through the objects "hit" by the projection view. Sometimes transparent or wireframe is showing it up better
Hi ave you tried to click several tims, normally you cycle through the objects "hit" by the projection view. Sometimes transparent or wireframe is showing it up better -- Good luck Ivar
Posted: 2 decades ago 2010/10/14 18:30 GMT-4
Thanks Ivar, I tried multiple times hit, it worked.
Irfan
Hi, Thanks Ivar, I tried multiple times hit, it worked. Thanks Irfan
Ruud Borger COMSOL Employee
Posted: 2 decades ago 2010/10/15 5:09 GMT-4
Hello Irfan,
In addition to what you tried, it can help to hide objects that are in front of it. The hide-buttons are located above the graphics window.
What's more, once you have selected those "buried" surfaces, it can be helpful to save the selection. To do this, go to "Definitions" and then "Add selection". Alternatively, when you have selected them under a boundary condition, there is a small button that will automatically save the current selection. Be sure to give it an appropriate name though!
Good luck,
Ruud Borger,
Comsol
Hello Irfan, In addition to what you tried, it can help to hide objects that are in front of it. The hide-buttons are located above the graphics window. What's more, once you have selected those "buried" surfaces, it can be helpful to save the selection. To do this, go to "Definitions" and then "Add selection". Alternatively, when you have selected them under a boundary condition, there is a small button that will automatically save the current selection. Be sure to give it an appropriate name though! Good luck, Ruud Borger, Comsol
Posted: 2 decades ago 2010/10/15 16:06 GMT-4
It is really wonderful and what I am looking for.
Irfan
Hi, It is really wonderful and what I am looking for. Thanks Irfan
Posted: 2 decades ago 2010/10/16 5:02 GMT-4
do not forget that you can have several views (under definitions and under Results (postprocessing) with different "hide" levels (only for views under Definitions)
Hi do not forget that you can have several views (under definitions and under Results (postprocessing) with different "hide" levels (only for views under Definitions) -- Good luck Ivar
Posted: 10 years ago 2016/01/05 0:00 GMT-5
Hi, I am trying to make one side of a triangle transparent but it is not working. Is there any simple way of doing it in Comsol 5.1 for ray optics module?
Jeff Hiller COMSOL Employee
Posted: 10 years ago 2016/01/06 9:54 GMT-5
This is now a really old thread, but I want to point out that the default way to select geometric entities like boundaries changed a while back. The following link should be useful when it comes to the more recent versions:
www.comsol.com/support/knowledgebase/1168/
This is now a really old thread, but I want to point out that the default way to select geometric entities like boundaries changed a while back. The following link should be useful when it comes to the more recent versions: http://www.comsol.com/support/knowledgebase/1168/ Best, Jeff
