2010/10/16 18:17 JST
have you tried to add a global equation u3=int(u1,0,2) and then force it to 10 ?
2010/10/16 20:01 JST
Hi, Ivar
Thanks for your help!
The error of "Unknown function. - Name: Int" was obtained when I followed your advice. The error occured again when "Int" was instead by "Integral". It seems that there was no built-in "integral function" in "Global equation".
Then how to handle it?
thank you very much!
youf.
Hi, Ivar
youf.
2010/10/16 23:33 JST
sorry for that int() is my shortcut for integration (Model coupling)
2010/10/17 19:43 JST
another thing, when I see a PDE solution that is oscillating in line with the mesh, I know by experience that then the BC are overconstraine and your equation set is not correct, so I believe your example is not a coherent set of equations and BC's, there is something too much in there ;)
2010/10/18 10:04 JST
Hi, Ivar
Thanks for your help very much!
I has tried the "integration (Model coupling)" setting, but unfortunately the satisfying result can not be obtained. I think I must tried again and the process is required for a new user of Comsol.
Thank you for testing the example. It has not real significance. What I want to know is setting the integral equation. The boundary conditions is really too many for the equations.
youf.
Hi, Ivar
youf.
