evaluating the field at a specific point
In my plots I want to normalize by the central value, ie. plot u(x,y)/u(0,0) Normally I just type 'u' to plot u(x,y), but is there some syntax for specifying u(0,0) as a constant?
--thanks, Chris
1 Reply Last Post 2016/03/09 22:25 JST
Jeff Hiller COMSOL Employee
Posted: 9 years ago 2016/03/09 22:25 JST
Hello Christopher,
You can use a Component Coupling of the Integration type, defined at the point (0,0). If it's the first such component coupling in your model this operator will be called intop1 by default (You can rename it, of course) and you would then refer to the value of u at (0,0) as intop1(u).
A toy example is attached.
If you have already solved your model and you need this solely for postprocessing purposes, you can force the evaluation of intop1 without recomputing the solution by using the "Update Solution" button located on the Study ribbon.
Component Couplings are a very powerful concept offered by COMSOL, so if you have never used component couplings before you will want to review the Reference Manual, version 5.2, page 281 and following to discover some of the fantastic things they can do for you (in short: all kinds of non-local couplings).
Hello Christopher, You can use a Component Coupling of the Integration type, defined at the point (0,0). If it's the first such component coupling in your model this operator will be called intop1 by default (You can rename it, of course) and you would then refer to the value of u at (0,0) as intop1(u). A toy example is attached. If you have already solved your model and you need this solely for postprocessing purposes, you can force the evaluation of intop1 without recomputing the solution by using the "Update Solution" button located on the Study ribbon. Component Couplings are a very powerful concept offered by COMSOL, so if you have never used component couplings before you will want to review the Reference Manual, version 5.2, page 281 and following to discover some of the fantastic things they can do for you (in short: all kinds of non-local couplings). Best, Jeff
