In Segregated Step 1: There was an error message from the linear solver. The relative error (2.2e+002) is greater than the relative tolerance.
Posted 2016/03/17 18:17 GMT-4 Studies & Solvers Version 5.2 1 Reply
Hi all,
Why does this error happen and how do I solve it?
This is the log file:
Minimum element quality: 0.03333
Stationary Solver 1 in Study 1/Solution 3 (sol3) started at 18-Mar-2016 08:12:59.
Nonlinear solver
Number of degrees of freedom solved for: 86118.
Nonsymmetric matrix found.
Scales for dependent variables:
Electric potential (mod1.V): 29
Displacement field (Material) (mod1.u): 6.5e-008
Pressure (mod1.p): 1e+005
Displacement field (Material) (mod1.u2): 1e-008
Orthonormal null-space function used.
Iter SolEst ResEst Damping Stepsize #Res #Jac #Sol LinErr LinRes
1 0.065 3.2 1.0000000 7.2 2 1 2 2.1e-010 1.9e-011
2 3e-006 0.00061 1.0000000 0.031 3 2 4 1.7e-010 8.3e-012
Stationary Solver 1 in Study 1/Solution 3 (sol3): Solution time: 3 s
Physical memory: 1.28 GB
Virtual memory: 1.41 GB
Time-Dependent Solver 1 in Study 1/Solution 3 (sol3) started at 18-Mar-2016 08:13:04.
Time-dependent solver (BDF)
Number of degrees of freedom solved for: 73170.
Pressure (mod1.p2): 1e+005
Velocity field, continuous phase (Spatial) (mod1.uc): 3.8e+002
Velocity field, dispersed phase (Spatial) (mod1.ud): 3.4e+002
Volume fraction, dispersed phase (mod1.phid): 0.0093
Step Time Stepsize Res Jac Sol Order Tfail NLfail LinErr LinRes
0 0 - out 22 15 22 0
Group #1: 11 3 11 0.005 1.2e-013
Group #2: 11 12 11 1.7e-013 1.5e-016
1 2.5e-005 2.5e-005 94 65 93 1 0 1
Group #1: 34 5 34 0.00032 5.8e-014
Group #2: 60 60 59 1.4e-013 2.2e-016
2 7.5e-005 5e-005 100 69 99 1 0 1
Group #1: 37 6 37 0.0094 3.9e-014
Group #2: 63 63 62 1.4e-013 2.2e-016
3 0.000175 0.0001 102 71 101 1 0 1
Group #1: 38 7 38 0.0024 5.5e-014
Group #2: 64 64 63 1.4e-013 1.8e-016
4 0.000375 0.0002 104 73 103 1 0 1
Group #1: 39 8 39 0.0047 2.8e-014
Group #2: 65 65 64 1.4e-013 1.7e-016
5 0.000775 0.0004 107 76 106 1 0 1
Group #1: 40 9 40 0.0042 1.6e-014
Group #2: 67 67 66 1.6e-013 1.8e-016
6 0.001575 0.0008 110 79 109 1 0 1
Group #1: 41 10 41 0.00086 2.2e-014
Group #2: 69 69 68 1.9e-013 1.6e-016
7 0.003175 0.0016 122 88 121 1 0 1
Group #1: 45 11 45 0.0078 3.5e-014
Group #2: 77 77 76 1.6e-013 1.6e-016
8 0.006375 0.0032 125 91 124 1 0 1
Group #1: 46 12 46 0.0054 7.2e-014
Group #2: 79 79 78 1.4e-013 1.5e-016
- 0.01 - out
9 0.012775 0.0064 150 109 149 1 0 1
Group #1: 54 13 54 0.00069 3.9e-014
Group #2: 96 96 95 1.6e-013 1.6e-016
- 0.02 - out
10 0.022775 0.01 190 133 189 1 0 1
Group #1: 71 14 71 0.0098 1.4e-014
Group #2: 119 119 118 2.4e-013 2.1e-016
- 0.03 - out
11 0.032775 0.01 195 137 194 1 0 1
Group #1: 73 15 73 0.004 1.1e-014
Group #2: 122 122 121 1.6e-013 2.1e-016
- 0.04 - out
12 0.042775 0.01 204 144 203 1 0 1
Group #1: 76 16 76 0.0082 5.6e-014
Group #2: 128 128 127 1.8e-013 1.6e-016
- 0.05 - out
13 0.052775 0.01 235 161 234 1 0 1
Group #1: 91 17 91 0.00085 8.7e-015
Group #2: 144 144 143 1.9e-013 1.6e-016
Warning: In Segregated Step 1:
Warning: There was an error message from the linear solver.
Warning: The relative error (2.2e+002) is greater than the relative tolerance.
Stopped
Time-Dependent Solver 1 in Study 1/Solution 3 (sol3): Solution time: 3143 s (52 minutes, 23 seconds)
Physical memory: 1.67 GB
Virtual memory: 1.74 GB
Nonlinear solver
- 0.01 - out
- 0.02 - out
- 0.03 - out
- 0.04 - out
- 0.05 - out
Stopped
1 Reply Last Post 2016/03/18 9:45 GMT-4
