Parametric Sweep in 4.0 not updating
Posted 2010/11/04 18:14 GMT-4 2 Replies
I am testing comsol 4.0a and trying to run a simple model with a parametric sweep. I selected the parameter name and input several values and then solved the model. I looked at the results and all appears well, however when I wanted to change the parameters and do another sweep (broaden the range of the variable a bit) it doesn't seem to refresh.
Specifically, I put in a new set of parameter values and "solved" the study. The progress bar in the solve reports it is solving the parametric run but when it finishes only the prior parametric sweep is available. No errors are reported.
1. How do I reset the model so it will detect this new set of parameters?
2. How do I delete old solutions and completely reset the model. In 3.5a this was possible ....
3. How do I monitor what parameter it is currently solving to confirm that it is working on the right thing?
Thanks in advance
Thanks in advance
2 Replies Last Post 2010/11/05 18:34 GMT-4
