define maximum mesh size which is a function of the independent variable?
Is it possible to define the maximum size of a mesh near a boundary to be a known function of position along that boundary? For example, in the problem of free convection at a vertical flat plate, it would be optimum to define a mesh which grows as z^(1/4), where z is vertical position along the plate. This way the mesh scales with the thickness of the boundary layer.
1 Reply Last Post 2010/12/07 8:34 GMT-5
Posted: 1 decade ago 2010/12/07 8:34 GMT-5
Have you tried defining the mesh size within a function defined w.r.t. {x.y.z} ?
in v4.1 you should be able to do that (must admit I havent tried so Iexpect it should work, cannot really tell ;)
Hi Have you tried defining the mesh size within a function defined w.r.t. {x.y.z} ? in v4.1 you should be able to do that (must admit I havent tried so Iexpect it should work, cannot really tell ;) -- Good luck Ivar
