How to control the material parameter with solution?
Posted 2010/12/07 22:17 GMT-5 Heat Transfer & Phase Change Version 4.1 3 Replies
Dear Experts,
I used Joule heating model of 2D problem. The geometry is a rectangle with a circle in the center. The resistivity of the circle is very high. Therefore, the current density will be increased around the circle. The resistivity of the rectangle is related with the current density. Simply, I set the resistivity rho_rect = 1e5 ohm.m at the area that current density above a certain value while the rho_rect at other area is zero.
When I used a expression with the variable ec.normJ in the heating model to define the material's resistivity, an error jumped like this
"Circular variable dependency detected.
- Variable: mod1.ec.normJ
- Geometry: 1
- Domain: 1"
Then I added mathmatics, using a PDE equation to describe the rho_rect. When I first set resistivity of rectangle constantly in Joule heating model, I can get the result that around the circle rho_rect was increased. However, when I set resistivity of rectangle from PDE. The solver cannot be convergence.
How can I resolve this problem? Is it a hard problem? I spent a lot of time on it.
Many Thanks!
Zhao
- Geometry: 1
- Domain: 1"
Many Thanks!
Zhao
3 Replies Last Post 2015/02/02 7:32 GMT-5
