2010/12/09 16:13 JST
check the XP and v4.1 compatibility in the relase notes, but for RAM and CPU's COMSOL will take what it finds available, so the more ram and CPU's the better (provided the RAM to CPU exchange speed is not saturating ;)
Jim Freels
mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
2010/12/13 22:21 JST
If your Windows-XP (or any other OS) is installed on a 32-bit machine, then COMSOL will only be able to take advantage of ~ 2 GB of RAM for a given model when solving (2^31-1). This is a limitation of the hardware, not the OS or COMSOL. If your OS is 64-bit on 64-bit hardware, then all the memory will be used by the COMSOL solver. I prefer Linux for many reasons, among which includes running COMSOL. Since I am an old FORTRAN coder, the code inserted below will demonstrate the concept (you can rewrite in your favorite language):
program test
implicit real*8 (a-h,o-z)
x=abs(2**31-1.)
xk=x/1024
xm=xk/1024
xg=xm/1024
write(*,*)x,xk,xm,xg
end
program test
x=abs(2**31-1.)
xk=x/1024
xm=xk/1024
xg=xm/1024
end
2010/12/13 22:39 JST
Hi James
I agree. I forgot to precise the OS decides first, no real use to run with >2Gb on a 32bit OS, if you are not using some virtual machine beneath, but anyhow COMSOL will not use more than the 2Gb on a 32b OS and that is really limited to at most 200-250kDoF in "client-server" mode.
And I see that the old Fortran stuff never dies out, just as us ;)
I havent either really catched up with C/C+/C# ..., to the level of my Fortran and assembler coding
Hi James
