Making interior fan works
Posted 2017/01/09 11:47 GMT-5 Version 5.2a 0 Replies
I am trying to make the interior fan boundary condition work on version 5.2a.
To do that I am building a simple rectangular model in 2D using Turbulent flow k-e.
My model consists of a rectangle to model a pipe in 2D with an inlet on the left BC with no initial flow (Uo = 0 m/s) flow and an outlet on the right BC. Now, I am drawing a vertical line halfway through the rectangle from the top BC to the bottom BC. I want to make this line an interior fan in order to create flow as if they were a turbine.
When trying to solve the model using using a default stationary solver, the error "the relative residual is greater than the relative tolerance" appears.
My guess is that there is something wrong with the way the geometry is set up.
Any help would be appreciated.
Hello Alexandre Mangot
