Error while using mphinterp function
Dear All,
please help me regarding mphinterp function.....
while using,
coordinate=[29970,10080]'
'' electric_field=mphinterp(model,'(es.Ey*es.ny)','coord',coordinate)''
in comsol 5.0 with matlab, i am always encountered with the error message
Error using mphinterp
mphinterp : Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Failed to evaluate
expression
(rethrown as com.comsol.util.exceptions.FlException)
Failed to evaluate expression
Cannot evaluate expression.
Undefined variable.
- Variable: comp1.es.ny
- Geometry: geom1
- Domain: 2
- Expression: real((comp1.es.Ey*comp1.es.ny))
- Expression: real(comp1.es.Ey*comp1.es.ny)
Error in Plea_Linepractice60micW_1micro_final29_2dModel (line
239)
3 Replies Last Post 2017/01/23 8:19 GMT-5
Posted: 9 years ago 2017/01/20 9:13 GMT-5
es.ny is only defined exactly on a boundary.
I suggest you try something like this:
[x,y,d]=mphinterp(model,{'x' 'y' 'es.Ey*es.ny'},'edim','boundary','selection',3,'coord',0:0.1:1);
and use the 'selection' property to select the boundary you are trying to extract data for.
Lars Gregersen
Comsol Denmark
Hi es.ny is only defined exactly on a boundary. I suggest you try something like this: [x,y,d]=mphinterp(model,{'x' 'y' 'es.Ey*es.ny'},'edim','boundary','selection',3,'coord',0:0.1:1); and use the 'selection' property to select the boundary you are trying to extract data for. -- Lars Gregersen Comsol Denmark
Posted: 9 years ago 2017/01/20 10:33 GMT-5
Hello Lars,
Thank you for responding so fast. Your valuable suggestion worked for me.
Asha Sharma
Hello Lars, Thank you for responding so fast. Your valuable suggestion worked for me. ---------- Asha Sharma
Posted: 9 years ago 2017/01/23 8:19 GMT-5
Hi Asha
You're welcome!
You can also do:
electric_field = mphinterp(model, 'es.Ey*es.ny', 'edim', 'boundary', 'coord', coordinate)
Lars Gregersen
Comsol Denmark
Hi Asha You're welcome! You can also do: electric_field = mphinterp(model, 'es.Ey*es.ny', 'edim', 'boundary', 'coord', coordinate) -- Lars Gregersen Comsol Denmark
