2011/01/31 22:28 JST
have you tried to analyse the "laser heatflux" in postprocessing mode? What about the solver options: do the time stepping options fit to the pulse frequency?
At least, you pulse function looks like a sharp saw - only one side is smooth. Not recommendable for numerical analysis ...
2011/01/31 22:31 JST
have you tried to plot that function ?
first there is a closing bracket ")" missing at the end, second it's a sawtooth when I try to plot it, the function is with a lot of discontinuities !!
The solver gets crazy on such functions. the Heaviside functions are there to "smoothen". So why not try a 0.5*(1-cos(2*pi*f*t)) then ?
And do not forget to set the solver stepping to intermediate, or strict, and to define sufficient points per period to resolve the sinus or your general periodicity
So I see I'm not alone here, I believe you have missed something in the periodicity of your function, it requires a little more tweaking
2011/02/01 0:21 JST
Thank you for your prompt replies the function is now working correctly.
It seems the error was in the discontinuities of my earlier function.
I would be lost without your help!
Thanks again.
Thanks again.
2011/05/03 11:28 JST
I know this maybe an old topic for you. As I am new to Comsol, I have problems to simulate the temperature rising of the plasmonic structure during the laser illumination. Assuming the Electromagnetic wave plus the heat transfer will do the job. According to the suggestion from the Comsol support, one heat source was added using the total power loss of the electromagnetic wave. However, it doesn't work.
Apprecieate any of your suggestions.
2011/08/03 6:53 JST
I am trying to model the pulse laser train. I am using flc2hs((mode(t.0.2)-0),1)-flch2hs((mod(t,0.2)-2e-12),1).
I multiply this by intensity to get the pulse train.
For some reason the COMSOL hangs when I am trying to run the program.
Can you help me to figure out the problem?
Amir
Amir
