Connecting the output of a heating element with surface temperature
Dear All,
Momentarily I'm working on a wall set up with an active wall heating system.
Now is the goal that the inside surface temperature of stays stable.
It can be seen as a heating element in the wall which output in Watt, is regulated by a sensor on the wall surface.
How can I model this in the program and is that even possible?
Besides, the Output of the heating system will vary, due to changing condition, therefore if it is possible is there a way to determine the output of the heating element in the wall in time?
Thanks on beforehand.
With kind regards,
Glenn Pennings
2 Replies Last Post 2017/03/10 13:52 GMT-5
Walter Frei COMSOL Employee
Posted: 9 years ago 2017/03/10 9:46 GMT-5
Dear Glenn,
It sounds as if you're describing a thermostat. If that is the case you may find these articles helpful:
www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
www.comsol.com/blogs/how-to-implement-a-delay-in-your-thermostat-simulation/
Best Regards,
Dear Glenn, It sounds as if you're describing a thermostat. If that is the case you may find these articles helpful: https://www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/ https://www.comsol.com/blogs/how-to-implement-a-delay-in-your-thermostat-simulation/ Best Regards,
Posted: 9 years ago 2017/03/10 13:52 GMT-5
Thank you very much for the reply.
I will take a look at it.
With kind regards,
Glenn Pennings
Thank you very much for the reply. I will take a look at it. With kind regards, Glenn Pennings
