Can the position of the Legends in plot be moved?
I want to display the legends on the plot, but It seems that the Legends are always in the right-up corner of a plot, and sometimes the Legends will overlap part of the data curves. Can the position of the Legends in plot be moved? (I use v4.0)
4 Replies Last Post 2014/10/13 18:02 JST
Posted: 1 decade ago 2011/02/09 5:18 JST
Hiu
I'm not sure in 4.0, but in 4.1, in the main plot node you can select one of the 4 corners of the plot for the legend "box"
Hiu I'm not sure in 4.0, but in 4.1, in the main plot node you can select one of the 4 corners of the plot for the legend "box" -- Good luck Ivar
Posted: 1 decade ago 2012/02/18 7:24 JST
Hey
Does anybody knows if there is a way to have a few more options for the legend position? I.e. right center? My plot has data in all four corners.
-Niklas
Hey Does anybody knows if there is a way to have a few more options for the legend position? I.e. right center? My plot has data in all four corners. -Niklas
Posted: 1 decade ago 2012/02/18 7:34 JST
not from my knowledge, I'm also miss a middle position, for many of my plots, at least in the height direction ;)
Hi not from my knowledge, I'm also miss a middle position, for many of my plots, at least in the height direction ;) -- Good luck Ivar
Posted: 1 decade ago 2014/10/13 18:02 JST
I know it is an old post - but I found a solution/workaround.
Simply make the scale on the X-axis longer. Then the legend will fit and it will not cover any of the data.
I know it is an old post - but I found a solution/workaround. Simply make the scale on the X-axis longer. Then the legend will fit and it will not cover any of the data.
