Jeff Hiller
        COMSOL Employee
                                9 years ago
                                2017/04/14 10:02 GMT-4
                                                    Hello George,
The software does offer capabilities to take advantage of symmetry and periodicity, if they exist in your physical phenomenon.
Here are some pointers:
www.comsol.com/support/knowledgebase/1038/
www.comsol.com/model/heat-sink-8574
www.comsol.com/model/forced-air-cooling-with-heat-sink-22041
                            Hello George,
https://www.comsol.com/support/knowledgebase/1038/
https://www.comsol.com/model/heat-sink-8574
https://www.comsol.com/model/forced-air-cooling-with-heat-sink-22041
                                Josh Thomas
        Certified Consultant
                                9 years ago
                                2017/04/14 10:12 GMT-4
                                                    George-
Exploiting symmetry is a great way to reduce computational expense.
First, consider if perhaps 2D axisymmetry could work for you (revolution symmetry with no change in azimuthal direction).
If no, consider if 1 or more mirror planes would produce the same results (geometry + physics) on either side of the plane.  Start slicing and dicing the full 3D geometry.  Keep track of symmetry planes and impose zero flux conditions on these planes.
Important point:  Always remember to reduce any TOTAL loading (heat source) amounts to be appropriate (e.g. a half symmetry total heat source should be reduced by a factor of 2.)  If using a heat density however do NOT reduce the amount as the denominator in the term (W/m^3) will adjust for dimensionality reduction accordingly.
Also, one nice feature in COMSOL is that you can re-constitute the full 3D geometries using revolved, sector, or mirror data sets under Results>Data Sets.  No one will ever know you only solved on reduced dimensionality!  Of course, you know the results would be the same ;)
Good luck!
Josh
Josh Thomas
AltaSim Technologies
OOPS -- Just saw Jeff beat me to a response!  Haha.
                            George-
Good luck!
Josh
Josh Thomas
