Asymetric magnetic field
Hi!
I'm using a magnetic field 2D model and a 50Hz frequency study.
I have three power-lines that transmit 3-phase currents. That is, each coil is 120[deg] phase shifted to the
other.
The power-lines are placed in [-9,0], [0,0] and [9,0] and all transits the same current magnitude with the
same frequency.
For some reason the total magnetic flux density normB is not symmetric around x=0. It will have a higher
peak on one of the sides. (Which side depends on which cable is the "reference" while the other are phase
shifted +-120 with respect to this).
Does anyone understand why normB is not symmetric? Any insight will be gladly appreciated.
(file attached)
Aksel
1 Reply Last Post 2017/05/15 6:06 JST
Posted: 8 years ago 2017/05/15 6:06 JST
You have other conductors besides the ones you have specified currents for. If I remove all the other conductors I get a symmetric solution for normB. I conclude that the other conductors are carrying nonzero currents.
DW Greve
DWGreve Consulting
You have other conductors besides the ones you have specified currents for. If I remove all the other conductors I get a symmetric solution for normB. I conclude that the other conductors are carrying nonzero currents. DW Greve DWGreve Consulting
