Finding the location of the maximum of a variable
Dear Comsol Community,
I am looking for a way to find the location of the maximum of a variable. Getting the maximum value is easy, but so far I have not been able to get the coordinates of the maximum, preferably without using Matlab. Does anyone know how to do this?
Best regards!
Christian
Edit: Removed typo in title
25 Replies Last Post 2016/08/30 6:26 JST
Posted: 1 decade ago 2011/02/21 20:03 JST
in V4 you can get the maximum value with an operator (in 3.5 you needed to go through matlab) but I'm not sure how to get the coordinates too. Good point,does anybody else have a quick work-around ?
Hi, in V4 you can get the maximum value with an operator (in 3.5 you needed to go through matlab) but I'm not sure how to get the coordinates too. Good point,does anybody else have a quick work-around ? -- Good luck Ivar
Daniel Smith COMSOL Employee
Posted: 1 decade ago 2011/02/23 0:22 JST
Hi, you can define a Maximum coupling operator, then pass in the independent variables as a second argument to query the location at which the maximum occurred. For example, say you solve for temperature, T, and you have a Maximum coupling operator, maxop1, then use:
maxop1(T,x) for the x-coordinate at which the maximum occurs
maxop1(T,y) for the y-coordinate at which the maximum occurs
Hi, you can define a Maximum coupling operator, then pass in the independent variables as a second argument to query the location at which the maximum occurred. For example, say you solve for temperature, T, and you have a Maximum coupling operator, maxop1, then use: maxop1(T,x) for the x-coordinate at which the maximum occurs maxop1(T,y) for the y-coordinate at which the maximum occurs
Posted: 1 decade ago 2011/02/23 1:09 JST
Hi Daniel
that is an interesting news (where is that (will be?) documented, and are there other nice ones like that ;)
Hi Daniel that is an interesting news (where is that (will be?) documented, and are there other nice ones like that ;) -- Good luck Ivar
Posted: 1 decade ago 2011/02/23 6:27 JST
Hi Daniel!
That is interesting indeed and worked well for me. Thank you! I guess it's time to update the documentation of Comsol ;o).
Best regards!
Christian
Hi Daniel! That is interesting indeed and worked well for me. Thank you! I guess it's time to update the documentation of Comsol ;o). Best regards! Christian
Posted: 1 decade ago 2011/02/23 16:34 JST
Hi again,
well now I see the explanations too:
Help: About Scalar Model Couplings and Operators - About Maximum and Minimum Model Couplings
"You can give two arguments, and the returned value is the value of the second argument evaluated in the max/min of the first argument."
A simple example would better illustrate its use
As usual, everything IS written in the doc it's "just" to find it and to understand it in the right context ;)
Have fun COMSOLING
Hi again, well now I see the explanations too: Help: About Scalar Model Couplings and Operators - About Maximum and Minimum Model Couplings "You can give two arguments, and the returned value is the value of the second argument evaluated in the max/min of the first argument." A simple example would better illustrate its use As usual, everything IS written in the doc it's "just" to find it and to understand it in the right context ;) -- Have fun COMSOLING Ivar
Posted: 1 decade ago 2011/02/23 17:41 JST
Hi Ivar!
You're right, thanks for hinting me at the right page. This information is actually missing on the page you get to when you use the dynamic help (Help > Definitions > Model Couplings > Maximum). As you said, an example or something like the interface definition of the operator would be nice on that page.
Best!
Christian
Hi Ivar! You're right, thanks for hinting me at the right page. This information is actually missing on the page you get to when you use the dynamic help (Help > Definitions > Model Couplings > Maximum). As you said, an example or something like the interface definition of the operator would be nice on that page. Best! Christian
Posted: 1 decade ago 2011/03/12 10:14 JST
When I try this it tells me "Wrong number of inputs". How can one variable recieve two values from one operator anyways? Do we have to do something special? As a newbie, I couldn't be more disgusted with how poorly this amazing software is documented.
Posted: 1 decade ago 2011/03/12 17:55 JST
No the trick with the min/max call is that you receive only one value in return, either the maximum value of the variable name given, called with (u), or the x location of the maximum of the variable given called with (u,x), or the "y" value of the maximum of the variable given, called with (u,y) and so on.
You need 2 calls to get all x,y,and max_of_(u) (4 in 3D ...
By the way the v4.1 doc is far better than the earl 4.0
Hi No the trick with the min/max call is that you receive only one value in return, either the maximum value of the variable name given, called with (u), or the x location of the maximum of the variable given called with (u,x), or the "y" value of the maximum of the variable given, called with (u,y) and so on. You need 2 calls to get all x,y,and max_of_(u) (4 in 3D ... By the way the v4.1 doc is far better than the earl 4.0 -- Good luck Ivar
Posted: 1 decade ago 2011/03/12 18:08 JST
So why do I get a "Wrong number of inputs" error when I try putting two values into the max operator?
Posted: 1 decade ago 2011/03/12 19:02 JST
Good question, the firt must be a dependet variable or a locally defined variable and the second must be one of the spatial coordinates variables, x,y,z r ... (the second variable is a name not a value)
but the confusion could perhaps be from the
max(1,2) and min(2,3) mathematical functions, and the
maxop1(u,x) minop1(v,y) "coupling operators"
all in v4
Hi Good question, the firt must be a dependet variable or a locally defined variable and the second must be one of the spatial coordinates variables, x,y,z r ... (the second variable is a name not a value) but the confusion could perhaps be from the max(1,2) and min(2,3) mathematical functions, and the maxop1(u,x) minop1(v,y) "coupling operators" all in v4 -- Good luck Ivar
Posted: 1 decade ago 2011/03/17 13:30 JST
I am using Model 1 -> Definitions -> Model Couplings - > Maximum and I am trying maxop(c,t) where c is concentration (a dependent variable) and t is time (an independent variable). I have tried spacial coordinate x instead of time t, also, and it gives the error regardless. However, I am wondering if the problem is with how I am trying to evaluate the operator... I am going to Model 1 -> Definitions -> Variables and trying to evaluate it there... should I be doing it somewhere in the results instead? This is completely confusing to a newbie!
Posted: 1 decade ago 2011/03/17 15:44 JST
Then I suppose its because it expects a coordinate variable and not a time "t" variable.
To get a time (or a sweep) maximum you must post process, Derived Variables export the max value to a table, and in the table perform a max operation (table option at the bottom of the GUI, it took me some time to discover this one, just as for the table transpose possibilities. Its worth to explore thoughtfully all GUIs there are a lot of hidden gems in there
Hi Then I suppose its because it expects a coordinate variable and not a time "t" variable. To get a time (or a sweep) maximum you must post process, Derived Variables export the max value to a table, and in the table perform a max operation (table option at the bottom of the GUI, it took me some time to discover this one, just as for the table transpose possibilities. Its worth to explore thoughtfully all GUIs there are a lot of hidden gems in there -- Good luck Ivar
Posted: 1 decade ago 2011/03/17 15:56 JST
but, like i said, I tried a coordinate variable x and it still gave the error. can you tell me where and how you would evaluate the location of the maximum coordinate variable?
Posted: 1 decade ago 2011/03/18 5:06 JST
well for me it works in my v4.1, (if you are in 2D-axi it's "r" and "z" and not "x", "y", normally).
The only other way I know about is the to export to Matalb and do a matrix "max" search
Hi well for me it works in my v4.1, (if you are in 2D-axi it's "r" and "z" and not "x", "y", normally). The only other way I know about is the to export to Matalb and do a matrix "max" search -- Good luck Ivar
Posted: 1 decade ago 2011/03/18 5:28 JST
you have an amazing ability of answering the question without actually answering the question, ivar ;) but at least you resond, so i appreciate that. i really do.
~roman
you have an amazing ability of answering the question without actually answering the question, ivar ;) but at least you resond, so i appreciate that. i really do. ~roman
Posted: 1 decade ago 2011/03/18 6:16 JST
I s this better ;) If you do not a little search yourself, you will never learn !
Hi I s this better ;) If you do not a little search yourself, you will never learn ! -- Good luck Ivar
Posted: 1 decade ago 2011/03/18 6:26 JST
yes, thank you for the wise advice, but trust me. i don't resort to this forum or to tech support unless i've spent days trying to figure out the problem on my own.
there is a difference in doing research on your own, or trying to find a needle in a hay stack. i've learned matlab on my own and they have everything documented such that i've used their support maybe 3 or 4 times in my life... whereas i've exceeded that with comsol in the first two weeks of use! and it is typical that you will wait a day for them to respond and they send you a generic response asking for more information, making it obvious that they didn't even bother to open the file that produces the error upon opening. once i waited over a week for them to respond, and in that week i figured out the problem on my own... so whats the point of contacting them?
yes, thank you for the wise advice, but trust me. i don't resort to this forum or to tech support unless i've spent days trying to figure out the problem on my own. there is a difference in doing research on your own, or trying to find a needle in a hay stack. i've learned matlab on my own and they have everything documented such that i've used their support maybe 3 or 4 times in my life... whereas i've exceeded that with comsol in the first two weeks of use! and it is typical that you will wait a day for them to respond and they send you a generic response asking for more information, making it obvious that they didn't even bother to open the file that produces the error upon opening. once i waited over a week for them to respond, and in that week i figured out the problem on my own... so whats the point of contacting them?
Posted: 1 decade ago 2011/03/18 6:42 JST
when you have tough problems, going deep inside COMSOL then the people at "support" are very useful.
My advice: get hands on the new v4.2, when it arrives within a few month I suppose. The pdf doc (I expect a few thousand pages) need to be read at least 3 times to get most out of it, Then you will be occupied for a month without touching COMSOL ;).
I needed 4 years of physics studies, to cover about the full field of COMSOL, it's somewhat more complex than Matlab in that sens, the latter is for me a nice math tool, but math I started rather young, at least for +/-* ... ;)
Then if possible, take a few of the COMSOL 1 day training courses, that will give you a good start, and come to the conferences, follow the mini-courses, meet the other users, it worth it (ps I'm not COMSOL, just a fan of the tool, it's really nice to run Physics like that an be able to observe in details the phenomenas)
Hi when you have tough problems, going deep inside COMSOL then the people at "support" are very useful. My advice: get hands on the new v4.2, when it arrives within a few month I suppose. The pdf doc (I expect a few thousand pages) need to be read at least 3 times to get most out of it, Then you will be occupied for a month without touching COMSOL ;). I needed 4 years of physics studies, to cover about the full field of COMSOL, it's somewhat more complex than Matlab in that sens, the latter is for me a nice math tool, but math I started rather young, at least for +/-* ... ;) Then if possible, take a few of the COMSOL 1 day training courses, that will give you a good start, and come to the conferences, follow the mini-courses, meet the other users, it worth it (ps I'm not COMSOL, just a fan of the tool, it's really nice to run Physics like that an be able to observe in details the phenomenas) -- Good luck Ivar
Posted: 1 decade ago 2012/11/03 12:48 JST
When I use in Matlab
A=mphglobal(model, 'maxop1(emw.Ey,x)'); trying to get the X position of the maximum Ey, it always goes wrong.
However, I can use A=mphglobal(model, 'maxop1(emw.Ey)'); to get the maximum Ey
Can you show me how to use maxop1 to get the position of the maximum in Matlab?
[QUOTE] Hi, you can define a Maximum coupling operator, then pass in the independent variables as a second argument to query the location at which the maximum occurred. For example, say you solve for temperature, T, and you have a Maximum coupling operator, maxop1, then use: maxop1(T,x) for the x-coordinate at which the maximum occurs maxop1(T,y) for the y-coordinate at which the maximum occurs [/QUOTE] When I use in Matlab A=mphglobal(model, 'maxop1(emw.Ey,x)'); trying to get the X position of the maximum Ey, it always goes wrong. However, I can use A=mphglobal(model, 'maxop1(emw.Ey)'); to get the maximum Ey Can you show me how to use maxop1 to get the position of the maximum in Matlab? Thanks
Posted: 1 decade ago 2012/11/14 7:36 JST
iomeg15,
You've probably long since moved on from this problem, but I think I understand your problem and how to fix it. When you generate the coupling maxop1, it's part of the problem definition, and not post-processing on the solution. If you generate the maxop1 and then try to use it without re-solving the solution it gives you the error you were seeing. If you update the solution though, then it works fine.
The others probably didn't catch this because having to update the solution was so obvious to them they probably didn't even think about needing to mention it.
iomeg15, You've probably long since moved on from this problem, but I think I understand your problem and how to fix it. When you generate the coupling maxop1, it's part of the problem definition, and not post-processing on the solution. If you generate the maxop1 and then try to use it without re-solving the solution it gives you the error you were seeing. If you update the solution though, then it works fine. The others probably didn't catch this because having to update the solution was so obvious to them they probably didn't even think about needing to mention it.
Posted: 1 decade ago 2012/11/14 8:03 JST
I've definitely moved on, lol. But its still nice to know, and I'll give your suggestion a try if I need this in the future (which I am sure I will). Thanks!
Posted: 1 decade ago 2012/11/14 15:36 JST
indeed, one often forget to update the results data base, once one add some functions or variables.
But one should also think it over, not all changes can be updated, some require resolving fully, and that COMSOL cannot always "identify" so in doubt => clear the results and solve again
Hi indeed, one often forget to update the results data base, once one add some functions or variables. But one should also think it over, not all changes can be updated, some require resolving fully, and that COMSOL cannot always "identify" so in doubt => clear the results and solve again -- Good luck Ivar
Posted: 1 decade ago 2013/04/10 3:53 JST
I have a trouble using this maximum finding operator when applied to a variable (Y-comp. displacement ) that is an output of a frequency domain analysis (Piezoelectric Devices physics). I am able to find the peak value of the displacement in a frequency response (let's say sweep range is 5...7 kHz) by using maxop1(pzd.uAmpY). Now, I want to know at which excitation frequency I get this peak displacement. If I use maxop1(pzd.uAmpY,freq) or maxop1(pzd.uAmpY, pzd.freq) I just get the maximum value of the sweep range (i.e. 7 kHz). Any ideas?
Cheers,
Rolanas
Hi, I have a trouble using this maximum finding operator when applied to a variable (Y-comp. displacement ) that is an output of a frequency domain analysis (Piezoelectric Devices physics). I am able to find the peak value of the displacement in a frequency response (let's say sweep range is 5...7 kHz) by using maxop1(pzd.uAmpY). Now, I want to know at which excitation frequency I get this peak displacement. If I use maxop1(pzd.uAmpY,freq) or maxop1(pzd.uAmpY, pzd.freq) I just get the maximum value of the sweep range (i.e. 7 kHz). Any ideas? Cheers, Rolanas
Posted: 9 years ago 2016/02/25 4:57 JST
very helpful answer.
i had just this problem and you solved it for me
Thank you.
I would just add that:
step 1: define maximum coupling operator under the component (comp #) definition
step 2: set the domain for which it will take the max
step 3: you can now call on the operator such that:
i. maxop1(T,x) for the x-coordinate at which the maximum occurs
ii. maxop1(T,y) for the y-coordinate at which the maximum occurs
iii. maxop1(T) for taking the max value of T itself
and don't forget to update the solution or run the solver after defining it, or else you will get an error message
very helpful answer. i had just this problem and you solved it for me Thank you. I would just add that: step 1: define maximum coupling operator under the component (comp #) definition step 2: set the domain for which it will take the max step 3: you can now call on the operator such that: i. maxop1(T,x) for the x-coordinate at which the maximum occurs ii. maxop1(T,y) for the y-coordinate at which the maximum occurs iii. maxop1(T) for taking the max value of T itself and don't forget to update the solution or run the solver after defining it, or else you will get an error message
Posted: 9 years ago 2016/08/30 6:26 JST
Cheers,
Rolanas
Hi Rolanas,
I have the exact same question: in a frequency domain analysis, I want to find the frequency at which a maximum happens (in my case maximum of a force, but the same issue). I can find the maximum force and that is very straightforward, but I also need the output to give me the frequency at which that happens too.
Have you found a solution or a way to achieve that?
Cheers,
Majd
[QUOTE] Hi, I have a trouble using this maximum finding operator when applied to a variable (Y-comp. displacement ) that is an output of a frequency domain analysis (Piezoelectric Devices physics). I am able to find the peak value of the displacement in a frequency response (let's say sweep range is 5...7 kHz) by using maxop1(pzd.uAmpY). Now, I want to know at which excitation frequency I get this peak displacement. If I use maxop1(pzd.uAmpY,freq) or maxop1(pzd.uAmpY, pzd.freq) I just get the maximum value of the sweep range (i.e. 7 kHz). Any ideas? Cheers, Rolanas [/QUOTE] Hi Rolanas, I have the exact same question: in a frequency domain analysis, I want to find the frequency at which a maximum happens (in my case maximum of a force, but the same issue). I can find the maximum force and that is very straightforward, but I also need the output to give me the frequency at which that happens too. Have you found a solution or a way to achieve that? Cheers, Majd
