cosmol -nn 2 -np 3 crashed.
when i ust the command "comsol -np 3", it sucessed. when i use the command "comsol mpd trace", it returns the names of the nodes that i can used.
but when I use the command "comsol -nn 2 -np 3". the comsol crashed. and it's error msg is like below:
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0000003ada4fbc6c, pid=2531, tid=47350084199856
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) 64-Bit Server VM (16.3-b01 mixed mode linux-amd64 )
# Problematic frame:
# C [libgtk-x11-2.0.so.0+0xfbc6c] gtk_icon_set_render_icon+0x58c
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0000000007f07800): JavaThread "main" [_thread_in_native, id=2531, stack(0x00007fff1da8a000,0x00007fff1dc8a000)]
siginfo:si_signo=SIGSEGV: si_errno=0, si_code=1 (SEGV_MAPERR), si_addr=0x0000000000000008
Registers:
RAX=0x0000000000000000, RBX=0x0000000000000000, RCX=0x0000000000000000, RDX=0x0000003ada67c108
RSP=0x00007fff1dc86ce0, RBP=0x0000000008ce96a0, RSI=0x0000000000000010, RDI=0x0000003ada662a61
R8 =0x0000000000000000, R9 =0x0000000000000001, R10=0x0000000000000009, R11=0x0000003ace874bd0
R12=0x0000000000000001, R13=0x0000000008dda020, R14=0x0000000008ce9670, R15=0x0000000000000000
RIP=0x0000003ada4fbc6c, EFL=0x0000000000010246, CSGSFS=0x0000000000000033, ERR=0x0000000000000004
TRAPNO=0x000000000000000e
Top of Stack: (sp=0x00007fff1dc86ce0)
0x00007fff1dc86ce0: 0000000007f47d10 0000003ada66cf9d
0x00007fff1dc86cf0: 0000000008ce7760 0000000008dcd820
0x00007fff1dc86d00: 0000000600000000 0000000000000000
0x00007fff1dc86d10: 0000000000000000 0000000000000000
0x00007fff1dc86d20: 0000000008dce380 0000003ada4fa374
0x00007fff1dc86d30: 0000000000000002 0000003ada66cf9d
0x00007fff1dc86d40: 0000000000000000 0000000000000000
0x00007fff1dc86d50: 0000000000000000 0000001800000018
0x00007fff1dc86d60: 0000000000000000 0000000000000000
0x00007fff1dc86d70: 0000000008dcd820 0000000008ce9670
0x00007fff1dc86d80: 0000000000000006 0000000000000000
0x00007fff1dc86d90: 0000003ad1c098f0 0000003ada6331aa
0x00007fff1dc86da0: 0000000000000000 00007fff1dc870a0
0x00007fff1dc86db0: 0000000008dcd858 0000000008dcd820
0x00007fff1dc86dc0: 0000000008dcd820 0000000000000001
0x00007fff1dc86dd0: 00000000000000f0 0000003ada50e0e1
0x00007fff1dc86de0: 00007fff1dc870c0 0000003ad1c2b565
0x00007fff1dc86df0: 0000000008dcd858 00000000081e7120
0x00007fff1dc86e00: 0000000008dcd820 0000003ada50e109
0x00007fff1dc86e10: 00000000081e7120 0000003ad0e9d640
0x00007fff1dc86e20: 0000000008dcd820 0000003ad1c0b220
0x00007fff1dc86e30: 00007fff1dc86f80 00007fff1dc870c0
0x00007fff1dc86e40: 000000021dc87108 0000000000000000
0x00007fff1dc86e50: 0000000040008002 0000000008dcd8d0
0x00007fff1dc86e60: 0000000008dcd8d0 0000000007fbcbd0
0x00007fff1dc86e70: 0100000e40008005 0000003ad0e9d640
0x00007fff1dc86e80: 00007fff1dc86f60 0000000008dcd820
0x00007fff1dc86e90: 0000000008116880 0000003ad0e9d640
0x00007fff1dc86ea0: 00007fff1dc86f80 0000000008dcd820
0x00007fff1dc86eb0: 0000000007fbcbd0 0000000000000000
0x00007fff1dc86ec0: 00007fff1dc87340 0000003ad1c1b80d
0x00007fff1dc86ed0: 0000000000000009 00007fff1dc870a0
Instructions: (pc=0x0000003ada4fbc6c)
0x0000003ada4fbc5c: 01 6e 16 00 48 8d 15 a1 04 18 00 be 10 00 00 00
0x0000003ada4fbc6c: 48 8b 48 08 31 c0 e8 e9 e5 f5 ff 48 8b 7c 24 70
Stack: [0x00007fff1da8a000,0x00007fff1dc8a000], sp=0x00007fff1dc86ce0, free space=7f30000000000000018k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x0000000007f9c800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2546, stack(0x00000000433d4000,0x00000000437d5000)]
0x0000000007f9a800 JavaThread "CompilerThread1" daemon [_thread_blocked, id=2545, stack(0x00000000432d3000,0x00000000433d4000)]
0x0000000007f95000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2544, stack(0x00000000431d2000,0x00000000432d3000)]
0x0000000007f93000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2543, stack(0x0000000042dd1000,0x00000000431d2000)]
0x0000000007f71800 JavaThread "Finalizer" daemon [_thread_blocked, id=2542, stack(0x00000000429d0000,0x0000000042dd1000)]
0x0000000007f6f800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2541, stack(0x00000000425cf000,0x00000000429d0000)]
=>0x0000000007f07800 JavaThread "main" [_thread_in_native, id=2531, stack(0x00007fff1da8a000,0x00007fff1dc8a000)]
Other Threads:
0x0000000007f6b000 VMThread [stack: 0x0000000041a40000,0x0000000041b41000] [id=2540]
0x0000000007f9f000 WatcherThread [stack: 0x00000000437d5000,0x00000000438d6000] [id=2547]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 42688K, used 9633K [0x00002b10c10a0000, 0x00002b10c4080000, 0x00002b10d65f0000)
eden space 40000K, 17% used [0x00002b10c10a0000,0x00002b10c1768718,0x00002b10c37b0000)
from space 2688K, 100% used [0x00002b10c3b80000,0x00002b10c3e20000,0x00002b10c3e20000)
to space 3904K, 0% used [0x00002b10c37b0000,0x00002b10c37b0000,0x00002b10c3b80000)
PSOldGen total 27328K, used 3714K [0x00002b10965f0000, 0x00002b10980a0000, 0x00002b10c10a0000)
object space 27328K, 13% used [0x00002b10965f0000,0x00002b1096990988,0x00002b10980a0000)
PSPermGen total 21248K, used 14117K [0x00002b10911f0000, 0x00002b10926b0000, 0x00002b10965f0000)
object space 21248K, 66% used [0x00002b10911f0000,0x00002b1091fb9690,0x00002b10926b0000)
Dynamic libraries:
00400000-00404000 r-xp 00000000 00:15 11567489 /home/kyo/Software/COMSOL40a/bin/glnxa64/comsollauncher
00504000-00505000 rw-p 00004000 00:15 11567489 /home/kyo/Software/COMSOL40a/bin/glnxa64/comsollauncher
07efc000-0903e000 rw-p 07efc000 00:00 0
4071f000-40722000 ---p 4071f000 00:00 0
40722000-40b20000 rwxp 40722000 00:00 0
410c1000-410c4000 ---p 410c1000 00:00 0
410c4000-414c2000 rwxp 410c4000 00:00 0
41a40000-41a41000 ---p 41a40000 00:00 0
41a41000-41b41000 rwxp 41a41000 00:00 0
41dc7000-41dc8000 ---p 41dc7000 00:00 0
41dc8000-41ec8000 rwxp 41dc8000 00:00 0
41ec8000-41ec9000 ---p 41ec8000 00:00 0
41ec9000-41fc9000 rwxp 41ec9000 00:00 0
41fc9000-41fca000 ---p 41fc9000 00:00 0
41fca000-420ca000 rwxp 41fca000 00:00 0
420ca000-420cb000 ---p 420ca000 00:00 0
420cb000-421cb000 rwxp 420cb000 00:00 0
421cb000-421cc000 ---p 421cb000 00:00 0
421cc000-422cc000 rwxp 421cc000 00:00 0
422cc000-422cd000 ---p 422cc000 00:00 0
422cd000-423cd000 rwxp 422cd000 00:00 0
423cd000-423ce000 ---p 423cd000 00:00 0
423ce000-424ce000 rwxp 423ce000 00:00 0
424ce000-424cf000 ---p 424ce000 00:00 0
424cf000-425cf000 rwxp 424cf000 00:00 0
425cf000-425d2000 ---p 425cf000 00:00 0
425d2000-429d0000 rwxp 425d2000 00:00 0
429d0000-429d3000 ---p 429d0000 00:00 0
429d3000-42dd1000 rwxp 429d3000 00:00 0
42dd1000-42dd4000 ---p 42dd1000 00:00 0
42dd4000-431d2000 rwxp 42dd4000 00:00 0
431d2000-431d5000 ---p 431d2000 00:00 0
431d5000-432d3000 rwxp 431d5000 00:00 0
432d3000-432d6000 ---p 432d3000 00:00 0
432d6000-433d4000 rwxp 432d6000 00:00 0
433d4000-433d7000 ---p 433d4000 00:00 0
433d7000-437d5000 rwxp 433d7000 00:00 0
437d5000-437d6000 ---p 437d5000 00:00 0
437d6000-438d6000 rwxp 437d6000 00:00 0
438d6000-438d9000 ---p 438d6000 00:00 0
438d9000-43cd7000 rwxp 438d9000 00:00 0
43cd7000-43cda000 ---p 43cd7000 00:00 0
43cda000-440d8000 rwxp 43cda000 00:00 0
440d8000-440db000 ---p 440d8000 00:00 0
440db000-444d9000 rwxp 440db000 00:00 0
444d9000-444dc000 ---p 444d9000 00:00 0
444dc000-448da000 rwxp 444dc000 00:00 0
3ace400000-3ace41a000 r-xp 00000000 08:01 5538079 /lib64/ld-2.5.so
3ace61a000-3ace61b000 r--p 0001a000 08:01 5538079 /lib64/ld-2.5.so
3ace61b000-3ace61c000 rw-p 0001b000 08:01 5538079 /lib64/ld-2.5.so
3ace800000-3ace94a000 r-xp 00000000 08:01 5538080 /lib64/libc-2.5.so
3ace94a000-3aceb49000 ---p 0014a000 08:01 5538080 /lib64/libc-2.5.so
3aceb49000-3aceb4d000 r--p 00149000 08:01 5538080 /lib64/libc-2.5.so
3aceb4d000-3aceb4e000 rw-p 0014d000 08:01 5538080 /lib64/libc-2.5.so
3aceb4e000-3aceb53000 rw-p 3aceb4e000 00:00 0
3acec00000-3acec02000 r-xp 00000000 08:01 5538081 /lib64/libdl-2.5.so
3acec02000-3acee02000 ---p 00002000 08:01 5538081 /lib64/libdl-2.5.so
3acee02000-3acee03000 r--p 00002000 08:01 5538081 /lib64/libdl-2.5.so
3acee03000-3acee04000 rw-p 00003000 08:01 5538081 /lib64/libdl-2.5.so
3acf000000-3acf015000 r-xp 00000000 08:01 5538085 /lib64/libpthread-2.5.so
3acf015000-3acf214000 ---p 00015000 08:01 5538085 /lib64/libpthread-2.5.so
3acf214000-3acf215000 r--p 00014000 08:01 5538085 /lib64/libpthread-2.5.so
3acf215000-3acf216000 rw-p 00015000 08:01 5538085 /lib64/libpthread-2.5.so
3acf216000-3acf21a000 rw-p 3acf216000 00:00 0
3acf400000-3acf482000 r-xp 00000000 08:01 5538087 /lib64/libm-2.5.so
3acf482000-3acf681000 ---p 00082000 08:01 5538087 /lib64/libm-2.5.so
3acf681000-3acf682000 r--p 00081000 08:01 5538087 /lib64/libm-2.5.so
3acf682000-3acf683000 rw-p 00082000 08:01 5538087 /lib64/libm-2.5.so
3acf800000-3acf814000 r-xp 00000000 08:01 15865225 /usr/lib64/libz.so.1.2.3
3acf814000-3acfa13000 ---p 00014000 08:01 15865225 /usr/lib64/libz.so.1.2.3
3acfa13000-3acfa14000 rw-p 00013000 08:01 15865225 /usr/lib64/libz.so.1.2.3
3ad0400000-3ad0407000 r-xp 00000000 08:01 5538086 /lib64/librt-2.5.so
3ad0407000-3ad0607000 ---p 00007000 08:01 5538086 /lib64/librt-2.5.so
3ad0607000-3ad0608000 r--p 00007000 08:01 5538086 /lib64/librt-2.5.so
3ad0608000-3ad0609000 rw-p 00008000 08:01 5538086 /lib64/librt-2.5.so
3ad0800000-3ad0805000 r-xp 00000000 08:01 15864478 /usr/lib64/libXdmcp.so.6.0.0
3ad0805000-3ad0a04000 ---p 00005000 08:01 15864478 /usr/lib64/libXdmcp.so.6.0.0
3ad0a04000-3ad0a05000 rw-p 00004000 08:01 15864478 /usr/lib64/libXdmcp.so.6.0.0
3ad0c00000-3ad0c9d000 r-xp 00000000 08:01 5538091 /lib64/libglib-2.0.so.0.1200.3
3ad0c9d000-3ad0e9c000 ---p 0009d000 08:01 5538091 /lib64/libglib-2.0.so.0.1200.3
3ad0e9c000-3ad0e9e000 rw-p 0009c000 08:01 5538091 /lib64/libglib-2.0.so.0.1200.3
3ad1000000-3ad1002000 r-xp 00000000 08:01 15866195 /usr/lib64/libXau.so.6.0.0
3ad1002000-3ad1201000 ---p 00002000 08:01 15866195 /usr/lib64/libXau.so.6.0.0
3ad1201000-3ad1202000 rw-p 00001000 08:01 15866195 /usr/lib64/libXau.so.6.0.0
3ad1400000-3ad1505000 r-xp 00000000 08:01 15865261 /usr/lib64/libX11.so.6.2.0
3ad1505000-3ad1705000 ---p 00105000 08:01 15865261 /usr/lib64/libX11.so.6.2.0
3ad1705000-3ad170c000 rw-p 00105000 08:01 15865261 /usr/lib64/libX11.so.6.2.0
3ad1800000-3ad1815000 r-xp 00000000 08:01 5538094 /lib64/libnsl-2.5.so
3ad1815000-3ad1a14000 ---p 00015000 08:01 5538094 /lib64/libnsl-2.5.so
3ad1a14000-3ad1a15000 r--p 00014000 08:01 5538094 /lib64/libnsl-2.5.so
3ad1a15000-3ad1a16000 rw-p 00015000 08:01 5538094 /lib64/libnsl-2.5.so
3ad1a16000-3ad1a18000 rw-p 3ad1a16000 00:00 0
3ad1c00000-3ad1c3e000 r-xp 00000000 08:01 5537844 /lib64/libgobject-2.0.so.0.1200.3
3ad1c3e000-3ad1e3e000 ---p 0003e000 08:01 5537844 /lib64/libgobject-2.0.so.0.1200.3
3ad1e3e000-3ad1e40000 rw-p 0003e000 08:01 5537844 /lib64/libgobject-2.0.so.0.1200.3
3ad2000000-3ad2010000 r-xp 00000000 08:01 15866668 /usr/lib64/libXext.so.6.4.0
3ad2010000-3ad2210000 ---p 00010000 08:01 15866668 /usr/lib64/libXext.so.6.4.0
3ad2210000-3ad2211000 rw-p 00010000 08:01 15866668 /usr/lib64/libXext.so.6.4.0
3ad2800000-3ad2803000 r-xp 00000000 08:01 5538092 /lib64/libgmodule-2.0.so.0.1200.3
3ad2803000-3ad2a02000 ---p 00003000 08:01 5538092 /lib64/libgmodule-2.0.so.0.1200.3
3ad2a02000-3ad2a03000 rw-p 00002000 08:01 5538092 /lib64/libgmodule-2.0.so.0.1200.3
3ad3400000-3ad3420000 r-xp 00000000 08:01 5537979 /lib64/libexpat.so.0.5.0
3ad3420000-3ad361f000 ---p 00020000 08:01 5537979 /lib64/libexpat.so.0.5.0
3ad361f000-3ad3622000 rw-p 0001f000 08:01 5537979 /lib64/libexpat.so.0.5.0
3ad4c00000-3ad4c29000 r-xp 00000000 08:01 15869554 /usr/lib64/libfontconfig.so.1.1.0
3ad4c29000-3ad4e29000 ---p 00029000 08:01 15869554 /usr/lib64/libfontconfig.so.1.1.0
3ad4e29000-3ad4e33000 rw-p 00029000 08:01 15869554 /usr/lib64/libfontconfig.so.1.1.0
3ad4e33000-3ad4e34000 rw-p 3ad4e33000 00:00 0
3ad6000000-3ad6009000 r-xp 00000000 08:01 15866672 /usr/lib64/libXrender.so.1.3.0
3ad6009000-3ad6208000 ---p 00009000 08:01 15866672 /usr/lib64/libXrender.so.1.3.0
3ad6208000-3ad6209000 rw-p 00008000 08:01 15866672 /usr/lib64/libXrender.so.1.3.0
3ad6c00000-3ad6c02000 r-xp 00000000 08:01 15874183 /usr/lib64/libXinerama.so.1.0.0
3ad6c02000-3ad6e01000 ---p 00002000 08:01 15874183 /usr/lib64/libXinerama.so.1.0.0
3ad6e01000-3ad6e02000 rw-p 00001000 08:01 15874183 /usr/lib64/libXinerama.so.1.0.0
3ad7000000-3ad703e000 r-xp 00000000 08:01 15871710 /usr/lib64/libpango-1.0.so.0.1400.9
3ad703e000-3ad723d000 ---p 0003e000 08:01 15871710 /usr/lib64/libpango-1.0.so.0.1400.9
3ad723d000-3ad7240000 rw-p 0003d000 08:01 15871710 /usr/lib64/libpango-1.0.so.0.1400.9
3ad7400000-3ad7417000 r-xp 00000000 08:01 15874004 /usr/lib64/libgdk_pixbuf-2.0.so.0.1000.4
3ad7417000-3ad7616000 ---p 00017000 08:01 15874004 /usr/lib64/libgdk_pixbuf-2.0.so.0.1000.4
3ad7616000-3ad7617000 rw-p 00016000 08:01 15874004 /usr/lib64/libgdk_pixbuf-2.0.so.0.1000.4
3ad7800000-3ad7808000 r-xp 00000000 08:01 15866701 /usr/lib64/libXi.so.6.0.0
3ad7808000-3ad7a07000 ---p 00008000 08:01 15866701 /usr/lib64/libXi.so.6.0.0
3ad7a07000-3ad7a08000 rw-p 00007000 08:01 15866701 /usr/lib64/libXi.so.6.0.0
3ad7c00000-3ad7c03000 r-xp 00000000 08:01 15866674 /usr/lib64/libXrandr.so.2.0.0
3ad7c03000-3ad7e02000 ---p 00003000 08:01 15866674 /usr/lib64/libXrandr.so.2.0.0
3ad7e02000-3ad7e03000 rw-p 00002000 08:01 15866674 /usr/lib64/libXrandr.so.2.0.0
3ad8000000-3ad800a000 r-xp 00000000 08:01 15866719 /usr/lib64/libXcursor.so.1.0.2
3ad800a000-3ad8209000 ---p 0000a000 08:01 15866719 /usr/lib64/libXcursor.so.1.0.2
3ad8209000-3ad820a000 rw-p 00009000 08:01 15866719 /usr/lib64/libXcursor.so.1.0.2
3ad8800000-3ad8808000 r-xp 00000000 08:01 15869452 /usr/lib64/libpangocairo-1.0.so.0.1400.9
3ad8808000-3ad8a08000 ---p 00008000 08:01 15869452 /usr/lib64/libpangocairo-1.0.so.0.1400.9
3ad8a08000-3ad8a09000 rw-p 00008000 08:01 15869452 /usr/lib64/libpangocairo-1.0.so.0.1400.9
3ada400000-3ada774000 r-xp 00000000 08:01 15864154 /usr/lib64/libgtk-x11-2.0.so.0.1000.4
3ada774000-3ada973000 ---p 00374000 08:01 15864154 /usr/lib64/libgtk-x11-2.0.so.0.1000.4
3ada973000-3ada97d000 rw-p 00373000 08:01 15864154 /usr/lib64/libgtk-x11-2.0.so.0.1000.4
3ada97d000-3ada97f000 rw-p 3ada97d000 00:00 0
3adaa00000-3adaa8f000 r-xp 00000000 08:01 15866723 /usr/lib64/libgdk-x11-2.0.so.0.1000.4
3adaa8f000-3adac8e000 ---p 0008f000 08:01 15866723 /usr/lib64/libgdk-x11-2.0.so.0.1000.4
3adac8e000-3adac93000 rw-p 0008e000 08:01 15866723 /usr/lib64/libgdk-x11-2.0.so.0.1000.4
3adae00000-3adae67000 r-xp 00000000 08:01 15865215 /usr/lib64/libcairo.so.2.9.2
3adae67000-3adb066000 ---p 00067000 08:01 15865215 /usr/lib64/libcairo.so.2.9.2
3adb066000-3adb069000 rw-p 00066000 08:01 15865215 /usr/lib64/libcairo.so.2.9.2
3adb200000-3adb205000 r-xp 00000000 08:01 15866697 /usr/lib64/libXfixes.so.3.1.0
3adb205000-3adb404000 ---p 00005000 08:01 15866697 /usr/lib64/libXfixes.so.3.1.0
3adb404000-3adb405000 rw-p 00004000 08:01 15866697 /usr/lib64/libXfixes.so.3.1.0
3adb600000-3adb62d000 r-xp 00000000 08:01 15869445 /usr/lib64/libpangoft2-1.0.so.0.1400.9
3adb62d000-3adb82d000 ---p 0002d000 08:01 15869445 /usr/lib64/libpangoft2-1.0.so.0.1400.9
3adb82d000-3adb82e000 rw-p 0002d000 08:01 15869445 /usr/lib64/libpangoft2-1.0.so.0.1400.9
3adba00000-3adba1c000 r-xp 00000000 08:01 15871708 /usr/lib64/libatk-1.0.so.0.1212.0
3adba1c000-3adbc1c000 ---p 0001c000 08:01 15871708 /usr/lib64/libatk-1.0.so.0.1212.0
3adbc1c000-3adbc1f000 rw-p 0001c000 08:01 15871708 /usr/lib64/libatk-1.0.so.0.1212.0
2aaaaaaab000-2aaaaaad3000 rw-p 2aaaaaaab000 00:00 0
2aaaaaad3000-2aaaaac6a000 r--s 02abf000 00:15 11897273 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/rt.jar
2aaaaac6a000-2aaaab5a6000 rw-p 2aaaaac6a000 00:00 0
2aaaab5a6000-2aaaab5a8000 r--s 0000a000 00:15 11896632 /home/kyo/Software/COMSOL40a/plugins/org.eclipse.equinox.launcher_1.0.201.R35x_v20090715.jar
2aaaab5a8000-2aaaab5b9000 r--s 00103000 00:15 11896595 /home/kyo/Software/COMSOL40a/plugins/org.eclipse.osgi_3.5.2.R35x_v20100126.jar
2aaaab5b9000-2aaaab5cc000 r-xp 00000000 00:15 12091497 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libnet.so
2aaaab5cc000-2aaaab6cd000 ---p 00013000 00:15 12091497 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libnet.so
2aaaab6cd000-2aaaab6d0000 rw-p 00014000 00:15 12091497 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libnet.so
2aaaab6d0000-2aaaab6d7000 r-xp 00000000 00:15 12091498 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libnio.so
2aaaab6d7000-2aaaab7d6000 ---p 00007000 00:15 12091498 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libnio.so
2aaaab7d6000-2aaaab7d8000 rw-p 00006000 00:15 12091498 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libnio.so
2aaaab7d8000-2aaaab7df000 r--s 00000000 08:01 15926564 /usr/lib64/gconv/gconv-modules.cache
2aaaab91a000-2aaaab925000 r-xp 00000000 00:15 12124217 /home/kyo/Software/COMSOL40a/lib/glnxa64/libcssystemutil.so
2aaaab925000-2aaaaba24000 ---p 0000b000 00:15 12124217 /home/kyo/Software/COMSOL40a/lib/glnxa64/libcssystemutil.so
2aaaaba24000-2aaaaba26000 rw-p 0000a000 00:15 12124217 /home/kyo/Software/COMSOL40a/lib/glnxa64/libcssystemutil.so
2aaaaba2f000-2aaaabac1000 r-xp 00000000 00:15 12091540 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libawt.so
2aaaabac1000-2aaaabbc0000 ---p 00092000 00:15 12091540 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libawt.so
2aaaabbc0000-2aaaabbd9000 rw-p 00091000 00:15 12091540 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libawt.so
2aaaabbd9000-2aaaabbfe000 rw-p 2aaaabbd9000 00:00 0
2aaaabbfe000-2aaaabc40000 r-xp 00000000 00:15 12091495 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/xawt/libmawt.so
2aaaabc40000-2aaaabd3f000 ---p 00042000 00:15 12091495 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/xawt/libmawt.so
2aaaabd3f000-2aaaabd4a000 rw-p 00041000 00:15 12091495 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/xawt/libmawt.so
2aaaabd4a000-2aaaabd4c000 rw-p 2aaaabd4a000 00:00 0
2aaaabd56000-2aaaabd5b000 r-xp 00000000 08:01 15871690 /usr/lib64/libXtst.so.6.1.0
2aaaabd5b000-2aaaabf5b000 ---p 00005000 08:01 15871690 /usr/lib64/libXtst.so.6.1.0
2aaaabf5b000-2aaaabf5c000 rw-p 00005000 08:01 15871690 /usr/lib64/libXtst.so.6.1.0
2aaaac000000-2aaaac402000 rw-p 2aaaac000000 00:00 0
2aaaac402000-2aaab0000000 ---p 2aaaac402000 00:00 0
2aaab0000000-2aaab007b000 r-xp 00000000 00:15 9348360 /home/kyo/Software/MATLAB/R2010b/bin/glnxa64/libfreetype.so.6.3.16
2aaab007b000-2aaab027b000 ---p 0007b000 00:15 9348360 /home/kyo/Software/MATLAB/R2010b/bin/glnxa64/libfreetype.so.6.3.16
2aaab027b000-2aaab0280000 rw-p 0007b000 00:15 9348360 /home/kyo/Software/MATLAB/R2010b/bin/glnxa64/libfreetype.so.6.3.16
2aaab0280000-2aaab02a4000 r-xp 00000000 00:15 9347812 /home/kyo/Software/MATLAB/R2010b/bin/glnxa64/libpng12.so.0.39.0
2aaab02a4000-2aaab04a4000 ---p 00024000 00:15 9347812 /home/kyo/Software/MATLAB/R2010b/bin/glnxa64/libpng12.so.0.39.0
2aaab04a4000-2aaab04a5000 rw-p 00024000 00:15 9347812 /home/kyo/Software/MATLAB/R2010b/bin/glnxa64/libpng12.so.0.39.0
2b108ce1e000-2b108ce20000 rw-p 2b108ce1e000 00:00 0
2b108ce20000-2b108ce22000 r-xp 00000000 00:15 12091534 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjsig.so
2b108ce22000-2b108cf21000 ---p 00002000 00:15 12091534 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjsig.so
2b108cf21000-2b108cf22000 rw-p 00001000 00:15 12091534 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjsig.so
2b108cf22000-2b108cf23000 rw-p 2b108cf22000 00:00 0
2b108cf2d000-2b108cf2f000 rw-p 2b108cf2d000 00:00 0
2b108cf2f000-2b108cf3d000 r-xp 00000000 00:15 11993149 /home/kyo/Software/COMSOL40a/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.0.200.v20090519/eclipse_1206.so
2b108cf3d000-2b108d03d000 ---p 0000e000 00:15 11993149 /home/kyo/Software/COMSOL40a/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.0.200.v20090519/eclipse_1206.so
2b108d03d000-2b108d03e000 rw-p 0000e000 00:15 11993149 /home/kyo/Software/COMSOL40a/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.0.200.v20090519/eclipse_1206.so
2b108d03e000-2b108d7f3000 r-xp 00000000 00:15 12091527 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/server/libjvm.so
2b108d7f3000-2b108d8f2000 ---p 007b5000 00:15 12091527 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/server/libjvm.so
2b108d8f2000-2b108da7d000 rw-p 007b4000 00:15 12091527 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/server/libjvm.so
2b108da7d000-2b108dab6000 rw-p 2b108da7d000 00:00 0
2b108dab6000-2b108dac3000 r-xp 00000000 00:15 12091503 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libverify.so
2b108dac3000-2b108dbc2000 ---p 0000d000 00:15 12091503 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libverify.so
2b108dbc2000-2b108dbc5000 rw-p 0000c000 00:15 12091503 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libverify.so
2b108dbc5000-2b108dbee000 r-xp 00000000 00:15 12091520 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjava.so
2b108dbee000-2b108dced000 ---p 00029000 00:15 12091520 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjava.so
2b108dced000-2b108dcf4000 rw-p 00028000 00:15 12091520 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjava.so
2b108dcf4000-2b108dcf5000 r--p 2b108dcf4000 00:00 0
2b108dcf5000-2b108dcf6000 rw-p 2b108dcf5000 00:00 0
2b108dcf6000-2b108dcfd000 r-xp 00000000 00:15 12091510 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/native_threads/libhpi.so
2b108dcfd000-2b108ddfe000 ---p 00007000 00:15 12091510 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/native_threads/libhpi.so
2b108ddfe000-2b108de00000 rw-p 00008000 00:15 12091510 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/native_threads/libhpi.so
2b108de00000-2b108de01000 rw-p 2b108de00000 00:00 0
2b108de01000-2b108de09000 rw-s 00000000 08:01 14876680 /tmp/hsperfdata_kyo/2531
2b108de0b000-2b108de15000 r-xp 00000000 08:01 5537820 /lib64/libnss_files-2.5.so
2b108de15000-2b108e014000 ---p 0000a000 08:01 5537820 /lib64/libnss_files-2.5.so
2b108e014000-2b108e015000 r--p 00009000 08:01 5537820 /lib64/libnss_files-2.5.so
2b108e015000-2b108e016000 rw-p 0000a000 08:01 5537820 /lib64/libnss_files-2.5.so
2b108e016000-2b108e024000 r-xp 00000000 00:15 12091508 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libzip.so
2b108e024000-2b108e126000 ---p 0000e000 00:15 12091508 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libzip.so
2b108e126000-2b108e129000 rw-p 00010000 00:15 12091508 /home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libzip.so
2b108e129000-2b108e12a000 rw-p 2b108e129000 00:00 0
2b108e12a000-2b108e39a000 rwxp 2b108e12a000 00:00 0
2b108e39a000-2b109112a000 rw-p 2b108e39a000 00:00 0
2b109112a000-2b1091134000 rw-p 2b109112a000 00:00 0
2b1091134000-2b10911ea000 rw-p 2b1091134000 00:00 0
2b10911f0000-2b10926b0000 rw-p 2b10911f0000 00:00 0
2b10926b0000-2b10965f0000 rw-p 2b10926b0000 00:00 0
2b10965f0000-2b10980a0000 rw-p 2b10965f0000 00:00 0
2b10980a0000-2b10c10a0000 rw-p 2b10980a0000 00:00 0
2b10c10a0000-2b10c4080000 rw-p 2b10c10a0000 00:00 0
2b10c4080000-2b10d65f0000 rw-p 2b10c4080000 00:00 0
2b10d65f0000-2b10d65fb000 rw-p 2b10d65f0000 00:00 0
2b10d65fb000-2b10d661a000 rw-p 2b10d65fb000 00:00 0
2b10d661a000-2b10d6628000 rw-p 2b10d661a000 00:00 0
2b10d6628000-2b10d676f000 rw-p 2b10d6628000 00:00 0
2b10d676f000-2b10d6788000 rw-p 2b10d676f000 00:00 0
2b10d6788000-2b10d681a000 rw-p 2b10d6788000 00:00 0
2b10d681a000-2b10d6829000 rw-p 2b10d681a000 00:00 0
2b10d6829000-2b10d6971000 rw-p 2b10d6829000 00:00 0
2b10d6971000-2b10d697c000 rw-p 2b10d6971000 00:00 0
2b10d697c000-2b10d699b000 rw-p 2b10d697c000 00:00 0
7fff1da8a000-7fff1da8d000 ---p 7fff1da8a000 00:00 0
7fff1da8d000-7fff1dc8a000 rwxp 7fff1da8d000 00:00 0 [stack]
7fff1dc8a000-7fff1dc8c000 rw-p 7fff1dc8a000 00:00 0
ffffffffff600000-ffffffffffe00000 ---p 00000000 00:00 0 [vdso]
VM Arguments:
jvm_args: -Dosgi.configuration.cascaded=true -Dosgi.checkConfiguration=true -Dosgi.sharedConfiguration.area=file:configuration/comsol -Dosgi.sharedConfiguration.area.readOnly=true -Dosgi.configuration.area=@user.home/.comsol/v40a/configuration/comsol -Dosgi.instance.area=@user.home/.comsol/v40a/workspace/comsol -Dcs.logoutput=file -Dcs.logfileprefix=comsol -Dcs.2drend=swt -Dcs.cluster=on -Xss4m -Xms40m -Xmx1024m -Dcs.mlroot=/home/kyo/Software/MATLAB/R2010b
java_command: <unknown>
Launcher Type: generic
Environment Variables:
PATH=/home/kyo/Software/MATLAB/R2010b/bin:/home/kyo/Software/COMSOL40a/ext/impi/glnxa64/bin:/opt/intel/Compiler/11.1/073/bin/intel64:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/opt/hpc-in-box//bin:/opt/xcat/bin:/opt/xcat/sbin:/home/kyo/bin://home/kyo/Software/MPICH2/bin://home/kyo/Software/Matlab/R2010a/bin:/opt/hpc-in-box//bin:/opt/xcat/bin:/opt/xcat/sbin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin:/bin:/usr/bin:/sbin:/usr/sbin:/usr/local/bin
LD_LIBRARY_PATH=/home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/server:/home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64:/home/kyo/Software/MATLAB/R2010b/bin/glnxa64:/home/kyo/Software/COMSOL40a/ext/impi/glnxa64/lib:/home/kyo/Software/COMSOL40a/ext/cadimport/glnxa64:/home/kyo/Software/COMSOL40a/lib/glnxa64/ipv4:/home/kyo/Software/COMSOL40a/lib/glnxa64:/opt/intel/Compiler/11.1/073/lib/intel64::/opt/hpc-in-box//lib:/opt/hpc-in-box//lib:/usr/lib64/xulrunner-1.9pre:/usr/lib64/xulrunner-1.9pre
LD_PRELOAD=/home/kyo/Software/COMSOL40a/java/glnxa64/jre/lib/amd64/libjsig.so
SHELL=/bin/bash
DISPLAY=:1.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x70ffd0], sa_mask[0]=0x7fffffff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x70ffd0], sa_mask[0]=0x7fffffff, sa_flags=0x10000004
SIGFPE: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGPIPE: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGXFSZ: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGILL: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x5db510], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGINT: [libjvm.so+0x5db260], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x5db260], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x5db260], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:Red Hat Enterprise Linux Server release 5.2 (Tikanga)
uname:Linux 2.6.18-92.el5 #1 SMP Tue Apr 29 13:16:15 EDT 2008 x86_64
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 10240k, CORE 0k, NPROC 137216, NOFILE 1024, AS infinity
load average:0.05 0.01 0.00
CPU:total 8 (4 cores per cpu, 1 threads per core) family 6 model 23 stepping 6, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1
Memory: 4k page, physical 16440344k(15019388k free), swap 1052248k(1052248k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (16.3-b01) for linux-amd64 JRE (1.6.0_20-b02), built on Apr 12 2010 13:57:11 by "java_re" with gcc 3.2.2 (SuSE Linux)
time: Sat Feb 26 09:26:58 2011
elapsed time: 26 seconds
any reply is appreciated.
Kyo
4 Replies Last Post 2012/07/05 16:38 GMT-4
Hello Yong LI
Posted: 1 decade ago 2011/04/11 10:23 GMT-4
I've also had this error in 4.1. I think it started with changing the graphics setting to DirectX instead of Open GL, but I'm not certain. I want to try to change it back, but I don't know if there are any settings files where I could do that. Anybody know anything about this error? I'm using Vista 64-bit.
Posted: 1 decade ago 2011/04/11 10:31 GMT-4
I had a lot of issues with the graphics when I was using an ATI Radeon graphic card. In the end I had to select the option 'Software' for 3D Renderin under Options-> Preferences.
If you want to revert to the original configuration you need to delete the folder 'v41' under the folder '.comsol' which should be located somewhere under Users\'YourUser'
Cheers
Hi, I had a lot of issues with the graphics when I was using an ATI Radeon graphic card. In the end I had to select the option 'Software' for 3D Renderin under Options-> Preferences. If you want to revert to the original configuration you need to delete the folder 'v41' under the folder '.comsol' which should be located somewhere under Users\'YourUser' Cheers
Posted: 1 decade ago 2011/04/11 15:31 GMT-4
Amir,
Thanks very much. Deleting the file worked perfectly and I seem to have no issues now that I'm using OpenGL to render. My guess is that I'm having some sort of DirectX version issue, but either way, it looks fine with OpenGL so I'll just go with it.
Thanks again,
-Matt
Amir, Thanks very much. Deleting the file worked perfectly and I seem to have no issues now that I'm using OpenGL to render. My guess is that I'm having some sort of DirectX version issue, but either way, it looks fine with OpenGL so I'll just go with it. Thanks again, -Matt
Posted: 1 decade ago 2012/07/05 16:38 GMT-4
Hello. I'm getting this same error with version 4.2a under Linux. I get it even when running comsol as a server and shouldn't be loading any graphical libraries (right?). It seems I can run comsol fine on my local machine, but the errors occur when I'm trying to launch comsol on the cluster.
In addition to the error message mentioned above, I get about 50 or so errors from (Comsollauncher:23039) relating to GLib objects, Gtk, Gdk, and Pango.
Any ideas?
Hello. I'm getting this same error with version 4.2a under Linux. I get it even when running comsol as a server and shouldn't be loading any graphical libraries (right?). It seems I can run comsol fine on my local machine, but the errors occur when I'm trying to launch comsol on the cluster. In addition to the error message mentioned above, I get about 50 or so errors from (Comsollauncher:23039) relating to GLib objects, Gtk, Gdk, and Pango. Any ideas?
