Work plane of finite size
Jorge Prada Microsensors
Hello all!, I'm interested into split an object in two domains using a work plane, which passes through 3 vertex lying around a narrow neck. I would like the object to be cut just across that narrow neck. Nevertheless, when using a work plane as cut tool, it extends across other regions of the same object, where I don't want the cut goes through. Please, how can I restrict the cutting extend or how can I limit the work plane extension? Thank you!
Jorge Enrique Prada Rojas
3 Replies Last Post 2017/10/27 23:21 JST
Jeff Hiller COMSOL Employee
Posted: 8 years ago 2017/10/27 2:51 JST
Updated: 8 years ago 2017/10/27 3:12 JST
Hi Jorge,
You can draw a suitable object in the workplane and partition using that object, as illustrated in the attached file.
Jeff Hiller
Hi Jorge, You can draw a suitable object in the workplane and partition using that object, as illustrated in the attached file. Best, Jeff
Posted: 8 years ago 2017/10/27 22:45 JST
Hi Jorge,
Thank you Jeff. It worked fine!
>Hi Jorge, > >You can draw a suitable object in the workplane and partition using that object, as illustrated in the attached file. > >Best, > >Jeff Thank you Jeff. It worked fine!
Posted: 8 years ago 2017/10/27 23:21 JST
Glad I could help!
Jeff Hiller
Glad I could help! Best, Jeff
