7 years ago
2017/12/13 15:39 JST
Dear friend,
You should first use a rule rot(rotE) = grad(divE) - laplace(E) and then use e.g. Coefficient Form PDE to define the equation you solve
Dear friend,
7 years ago
2017/12/13 20:01 JST
Thanks for your reply. Indeed I tried to use the rule rot(rotE) = grad(divE) - laplace(E) at first. However, I cannot find a suitable Coefficient Form PDE to express the grad(divE) term. That's why I ask the question.
Robert Koslover
Certified Consultant
7 years ago
2017/12/14 13:11 JST
Updated:
7 years ago
2017/12/14 13:19 JST
FYI, your PDE has a name. It is called the "Inhomogeneous Helmholtz Equation." (See https://en.wikipedia.org/wiki/Helmholtzequation ). If you haven't already done so, I suggest you take a look at the Comsol RF Module, 3D, frequency domain (emw). This module lets you solve the homogeneous version of this equatiion, subject to various boundary and volume conditions. I suspect there is a fair chance that you can re-express your quantity f (which makes the equation inhomogeneous) in terms of an equivalent boundary or volume condition. Good luck.
7 years ago
2017/12/15 6:09 JST
Hi, are you sure there are no discontinuities in material properties? If so, then there is probably a term that was once inside the curl(curl()) and if so then your field is not best discretized by Lagrange elements but instead by curl elements. They come for free if you have purchased the RF Module :-)
On a different note, you dont mention boundary conditions. For RF fields, the normal vector field is undefined on the boundary, but the tangential field is known. In return there is a constraint on divergence throughout the domain. Curl-elements are appropriate for tangential constraints. If you have an arbitrary divergence but constraints on the full three components on the boundary it starts to look more like Stokes equation.
Which is it?
With regard the coefficient formula for grad(div(E)) maybe it is a bit ugly in 3D. Nicer might be to use a weak formulation of the PDE and do integration by parts in which case you have get an integral of the form div(testE) * div(E)
Regards, J.
Which is it?
Regards, J.
