problem to propagate a gaussian beam or plane wave
Hi everybody,
I'm using Comsol 4.1 in order to propagate a gaussian beam on grating coupler. I started with 2D situation where I defined materials, mesh, an input port and PML condition on boundaries in order to absorb any reflection.
I have already successfully simulated this same situation with previous comsol 3.5a using "harmonic propagation" section of RF module. I followed indications found in "photonic cristal" tutorial model to set all parameters in Electromagnetics Wave, but the result is zero everywhere. It seems that I have not any excitation at port, while instead I have previously have defined a gaussian input.
I'm sure that boundary condition are exact, but it doesn't work as I want.
Can anyone help me?
thanks...
3 Replies Last Post 2011/08/21 18:12 JST
Hello Marco Paolo Bolzoni
Posted: 1 decade ago 2011/08/03 0:50 JST
I have currently quite the same problem than you. I would like to know if you fixed the problem you have mentionned.
Thank you for your answer.
Nicolas
Hello, I have currently quite the same problem than you. I would like to know if you fixed the problem you have mentionned. Thank you for your answer. Best regards, Nicolas
Posted: 1 decade ago 2011/08/04 14:59 JST
If port is outside PML layer it may be damped and there is no excitation inside? are you using scattered or full field computation?
Posted: 1 decade ago 2011/08/21 18:12 JST
hi
i want to have a simulation for get reflection from mirror and i need use from gaussian and parxial source.i have a problem for define the paraxial source can anyone help me? i work with 3.5a version of comsol it is possible to send me your simulation of gaussian beam simulation in comsol 3.5a?
i need reflect optic beam from the surface and i cant defind boundery condition.how can define it?
hi i want to have a simulation for get reflection from mirror and i need use from gaussian and parxial source.i have a problem for define the paraxial source can anyone help me? i work with 3.5a version of comsol it is possible to send me your simulation of gaussian beam simulation in comsol 3.5a? i need reflect optic beam from the surface and i cant defind boundery condition.how can define it?
