2011/04/22 5:59 JST
Its not evident to tell, that "function" name does ring a bell for me.
Have you checked that there is not a Global or a Model function node that remains ?
and have you tried to reset the model, save it and open a fresh COMSOL session ?
Sometimes it solves the case
2011/04/22 7:08 JST
Thanks Ivar, appreciate the usual, quick answer.
I haven't thought about resetting, will give it a try first thing tomorrow.
I am not sure what you mean by 'Global or a Model function node that remains'. I mean - most likely there aren't such things because I tried to make sure after the many alterations I did that only the necessaray things remained, yet to make sure I need to understand precisely what you mean. Can you please explain?
Cheers,
Mike
Cheers,
Mike
2011/04/22 7:56 JST
In V4 you can define functions in the Model - Definitions node, but also in the upper Global Definitions node
2011/04/22 8:47 JST
OK. I only have functions defined in the global definitions node (the ones I referred to before), plus a few variables in the model definitions node. So no luck hear, I also restarted the model but it did not change the outcome (still the same error).
Thanks for the tips anyway, I realize without looking at the model it is hard to pinpoint the problem.
Thanks.
Thanks.
2011/06/09 17:57 JST
extm1 appears to be a Matlab function call...
I am having the same problem, I was wondering if you found a solution?
2011/06/09 20:08 JST
often its easier to turn on "tag" names to follow the debug messages, as the references for java and matlab are the "tag" names extm1 could be tranlated to "EXTernal Matlab 1" operator/function, indeed
2011/06/09 21:07 JST
I found the root of the problem (at least for this error).. I had installed a new version of Matlab, and after updating the .ini files (
www.comsol.com/support/knowledgebase/1113/), Comsol was still not properly referencing the Matlab functions from the GUI (perhaps a problem with the path to the Matlab scripts). I solved the problem by deleting the Matlab function node, and then adding a new one back calling the same functions.
I found the root of the problem (at least for this error).. I had installed a new version of Matlab, and after updating the .ini files (http://www.comsol.com/support/knowledgebase/1113/), Comsol was still not properly referencing the Matlab functions from the GUI (perhaps a problem with the path to the Matlab scripts). I solved the problem by deleting the Matlab function node, and then adding a new one back calling the same functions.
