2 decades ago
2009/11/20 22:32 JST
I have also seen this for long listings, it's correct, and I forgot to submit that case to support the other day.
These are typical cases to submit to SUPPORT.
I believe this has to do with the memory management, have seen similar problems in other softwares, for their graphics too, could be a Java issue.
Mostly you find out how to reorder the data by hand but its annoyng, I agree.
This is one of the very few true "bugs" I have seen so far over the last years of my COMSOL use, most other so called bugs I have observed are misunderstandings on the model build-up and behaviour, we apply quite some level of physics here ;)
Another way to get the data is to catch the command in the history file and import the variables directly into Matlab
For me a good example to submit to support, but send them a model with the error so they can easily reproduce it, otherwise it's difficult for them to understand
2 decades ago
2009/11/21 8:08 JST
I had the same problem earlier this week. Spent a few hours trying to figure out what was going on. Eventually I just had Matlab order them correctly.
I should point out that your problem was with exporting it as an ASCII file, but I actually encountered the same problem with the posteval function on boundaries. Its annoying, but at least there's an easy workaround.
Mike
Mike
2 decades ago
2009/11/21 17:05 JST
I hope some COMSOL developpers are passing by here to !!
2 decades ago
2009/11/21 19:29 JST
Hi again,
aother way out (hope we do not have the same error is described at p489 [V3.5a] of the User guide:
"Exporting Postprocessing Data to a File"
Hi again,
2 decades ago
2009/11/21 21:40 JST
Thanks Ivar and Mike,
There is another problem in the same context: When exporting multiple curves in one plot, the data of the different curves are not separated also, which means that you have to do it by yourself!!!
Yes, I hope that some COMSOL developers are passing by this thread.
Cheers,
Cheers,
