2011/05/03 15:05 JST
it depends ;)
in what dimensions are you using ? a Boundary is a surface in 3D, or a line in 2D.
So if you are in 2D and V4, you may add a line plot : right click Results add 1D plot group. Then right click this new node and add a line graph, select your boundary and set your variable (CNTRL + SPACE gives yuo the default list)
if you are in 3D a boundary requires a "2D plot group to which you add "surface" plot node.
If you want to do a line cut plot on a 2D surface boundary (another case) then you can do this by creating a new Data set (right click "Data Sets" and add a split line + coordinates, or select an edge if it exist for your case
One thing forget 4.0a, get a newer 4.1 patched version, see with your local COMSOl rep, or sysadmin
it depends ;)
2011/05/03 15:08 JST
Thanks IVAR.
I am sorry but there was my mistake.
I mean the boundary "height" plot.
Can I plot the 1-D height boundary plot?
Thanks IVAR.
2011/05/03 15:28 JST
That is a good question !
Indeed, that one I do not see in V4, for 1D,
it's there for 2D, as a sub node of the surface plot.
Perhaps something to ask support about, and call it a suggestion for next release ;)
