Why the imported 3D variable through the “interpolation” does not imported correctly in COMSOL?
Posted 2018/06/20 10:39 JST Structural & Acoustics, Geomechanics Version 5.3 3 Replies
I have a solid mechanics problem to solve by COMSOL. The answer of first one (such as stress or displacement ) later replace as position dependent variable in second one.
There is two option. One way to do that is to export the answer from “Data Export” as a txt file and later import it in second COMSOL model by “interpolation”. Other way is to have two physics in one model and connect them by “Value of variable not solved for “in the sitting of “study”. When I import the data in second way and got the plot from the “interpolation” window everything is fine.
Unfortunately, there is problem with first way and the result at the end is not exactly same. Take von mises as a example. Maximum error can reach 14%. The error is mainly concentrated at the bottom.
With the nonlinear enhancement, the error is bigger and it locate in the all area. Maximum error can reach 60%.
I found that there is a difference between what I imported and what is read from those data.I don’t need interpolation. I will use same mesh. Therefore I just need to import a 3D variable correctly. The imported data is quite nonlinear. I look forward to hearing from you soon .
