Josh Thomas
Certified Consultant
7 years ago
2018/07/03 2:27 JST
Ramin-
A couple points:
1) If you want to include the effect of the vertical load in Study2 then you should not disable it in that study.
2) If your analyses are linear (i.e. no geometric or material non-linearities) then there is no benefit of initializing subsequent studies with initial values of variables solved for.
Josh Thomas
AltaSim Technologies
Ramin-
A couple points:
7 years ago
2018/07/03 3:21 JST
Ramin-
A couple points:
Dear Josh,
Thanks for your response.
It's just a simple model to see how 2-step analysis works and is not the real model that I'm working on.
About the first point you mentioned, the purpose of having a 2-step analysis is to use the results of the first step (or study) as initial values of the second study/step. Then, why should we include the vertical load in the second study anaig? This is the same problem that I have with "Tunnel excavation" example. I have already asked few questions regarding that example but haven't received any response. Maybe, if you had some free time, you could please take a look at these 3 issues.
1- In this example, for initialization, we are using External Stress in solid2 and step#2 (from gravity analysis in solid and step#1), but solid2 again considers gravity! If we are using stresses from the gravity analysis in step1, shouldn't we remove gravity from solid2?! Having both External Stresses and gravity in solid2 does not double the response?
2- For initialization, we are just considering external stress?! What about displacement (strains)?
3- And finally, in the results part, everything is based on sol1 (Data/Data set/study 1/solution 1 (sol1). What about sol2? shouldn't "after excavation" results be based on sol2? If not, then what is the point of having sol2 in the drop-down menu of Data/Data set?
Thanks in advance.
Ramin
>Ramin-
>A couple points:
Dear Josh,
Thanks in advance.
Ramin
Henrik Sönnerlind
COMSOL Employee
7 years ago
2018/07/03 15:28 JST
A quick remark on the data sets: 'dset1' is the final solution. 'dset2' corresponds to 'sol2' which is the solution after the first step ('Solution Store 1' in the solver sequence).
About the precedure, Josh is (as usual) right.
Henrik
Henrik Sönnerlind
COMSOL
Henrik
