2009/11/28 3:19 GMT-5
I'm not sure to have catched all, but for me if you have a time depending function you can use bolean functions to make piecevise Boundary condition variables
T=T1*(t<1)+T2*(t>=1)*(t<5) ...
to make the transitions smoother and derivable, use rather heaviside functions, you will find them in the Comsol documentation
You can also make global functions and apply them, then at least you should assure that they have defined derivatives
T=T1*(t=1)*(t
2009/11/28 4:59 GMT-5
Hi Ivar,
Attached herewith is the model file.
Here 4 variables are there. At present I am using a single BC and trying to solve. Once it is succesful, I need to use a periodic BC.
First about the present model. I need to put left boundary condition like this: Yg=0.0195 and Tg=300K. All other BC are adiabatic & impermiable ie insulated.So is it right to set BC as Dirichlit and specifying h=0.0195 & h=300 in the respective boxes as done in the file? Is this right?
Is correct to put all other BCs are Neumann to define as insulated.?( I mean no variation with x)?
Once this is done, I need to try for periodic BC. This problem I am trying to solve for the period t= 0 to 100. For the period 0-50, BC1(Yg=0.0195 and Tg=300K) to be applied and for period 50-100,BC2(Yg=0.008 and Tg=360K) to be applied. How is this to be done?
Thanks a lot
Regards
Ramadas
Hi Ivar,
Thanks a lot
Regards
Ramadas
2009/11/29 22:50 GMT-5
Hi Niklas/ Ivar
Can anyone answer this ?
Your reply well appreciated
Regards
Ramadas
Hi Niklas/ Ivar
Regards
Ramadas
