                                7 years ago
                                2018/07/26 8:33 GMT-4
                                                    Hi Mohammad,
Did you open the "COMSOL with Livelink" program or just the "COMSOL"?
Nichal
                            Hi Mohammad,
Nichal
                                7 years ago
                                2018/07/27 10:30 GMT-4
                                                    Hi Nichal
I open the Comsol With Matlab program at the first step, then I open a specific comsol program ( e.g : prj1.mph ) at the second step .
when I write the command "mphopen" in "matlab command window" and select the comsol project( prj1.mph) , it shows :
warning : the file is read only
This is exactly what I wrote and got :
    mphopen
    Warning: The file "D:\comsol\projects\prj1.mph" is read-only
    The COMSOL model is now accessible using the variable 'model'.
Thannks for  your consideration,
Mohammad
                            Hi Nichal
>> mphopen
Mohammad
                                7 years ago
                                2018/07/27 10:57 GMT-4
                                                    I am afraid I can not help more than trying to guess because I just recently start to work with livelink...
Here are some suggestions though:
-> if you are using linux start livelink using the command: comsol server matlab
-> if you are using a computador that is not yours check the permission of the folder where you saved the file
-> try to save the file in another folder and see if it helps
-> if the .mph file is not yours check the permissions of it within COMSOL
Hope any of these help you Mohammad
Nichal
Nichal
