An unexpected error occurred while opening comsol
Help! Help! Help! Yesterday, I used Comsol normally, but today I can not open it anymore. The detail error is given as follows. The solution to rename/remove the vXX folder located at C:\Users\%USERNAME%.comsol\vXX is also useless! Someone can help me?
2018-09-13T10:46:20.116+08:00 FlLocale - SystemProperties do not contain any locale setting. 2018-09-13T10:46:20.438+08:00 Constructing a FlLocale:zh_CN
2018-09-13T10:46:20.868+08:00 Could not load file or assembly 'cstextrenderer_wpf.dll' or one of its dependencies. Not a valid Win32 application. (Exception from HRESULT: 0x800700C1)
2018-09-13T10:46:20.872+08:00 at ComsolDesktop.TextRenderer.CsTextRenderer.Init(String distrDir) at ComsolDesktop.DesktopApplication..ctor() at ComsolDesktop.App.OnStartup(StartupEventArgs e) at System.Windows.Application.<.ctor>b__1(Object unused) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
1 Reply Last Post 2018/10/22 23:39 GMT-4
Hello Songcai Han
Posted: 7 years ago 2018/10/22 23:39 GMT-4
The main reason is that your Windows system has been updated automatically, which may cause some System files to have been modified. The best solution is to use the DirectX tool to repair the computer system. The problem can be usually solved smoothly.
