2011/08/18 14:57 JST
draw lines close to the values you want with a mouse, then edit the numerical values the the final desired ones.
if its a right angle, draw a box, add the diagonal, then split the curve and keep only the three desired, combine the lines into a "solid"
2013/08/06 2:01 JST
I think the easy way is to select to draw a Polygen but you can set three point out of the five to sit on eachother, this way it will become a triangle.
Regards
Yashar
Regards
Yashar
2013/08/06 2:32 JST
Use polygon feature. Define the x,y or (r,z) coordinates for the 3 points in the right order. Plot. This should work.
2013/08/06 2:38 JST
Sorry. i work on 4.3.
