Contact pairs
Hi there,
I am trying to simulate conduction and convection heat transfer. Can I consider the fluid solid interaction boundary as a contact pair? [ As we now from comsol that we can consider the contact surfaces between two different solids as a pair.] After that from physics menu- boundary settings we can set the contact pair boundary condition as thin thermally resistive layer after that we can add thickness and layer thermal conductivity.
The question if that possible which thermal conductivity we should choose?
I hope my question is clear!
2 Replies Last Post 2011/09/09 16:40 JST
Posted: 1 decade ago 2011/09/09 15:30 JST
Hi I cannot remeber how it was in 3.5 but I beleive (do not have access to my COMSOl just now) that you can add a thin resisitve layer on internal boundaries in V4
Hi I cannot remeber how it was in 3.5 but I beleive (do not have access to my COMSOl just now) that you can add a thin resisitve layer on internal boundaries in V4 -- Good luck Ivar
Posted: 1 decade ago 2011/09/09 16:40 JST
Thank you Ivar,
I had added that thin resistive layer and I've got results. One parameters of this thin resistive layer is thermal conductivity. Which thermal conductivity should I add, for liquid or fluid? I've tried both and the results are similar. Second in comsol documentaions pairs is used between two different contact solids, i.e., to mimic the small gap betweent solids due to surface roughness? My main question is: Is physically correct in COMSOL to use pairs to simulate the convection process occurs near solid boundary?
Thanks Ivar
Thank you Ivar, I had added that thin resistive layer and I've got results. One parameters of this thin resistive layer is thermal conductivity. Which thermal conductivity should I add, for liquid or fluid? I've tried both and the results are similar. Second in comsol documentaions pairs is used between two different contact solids, i.e., to mimic the small gap betweent solids due to surface roughness? My main question is: Is physically correct in COMSOL to use pairs to simulate the convection process occurs near solid boundary? Thanks Ivar
