How to calculate the area or volume surrounded by contour ?
Hi! ,friend. Such as the title ,my comsol version is 4.1.
Thank you very much!
3 Replies Last Post 2015/02/15 1:20 JST
Posted: 1 decade ago 2011/09/27 14:50 JST
intop(1) over a domain gives a volume (in 3D) over a boundary gives you the area (in 3D), decrease the dimension by 1 for 2D models
intop(1) means the integration over the defined (selected) domain (resp boundary ...) of 1*dx*dy*dz
Which is the definition of a mathematical way to calculate the volume respectively the surface, no ?
Hi intop(1) over a domain gives a volume (in 3D) over a boundary gives you the area (in 3D), decrease the dimension by 1 for 2D models intop(1) means the integration over the defined (selected) domain (resp boundary ...) of 1*dx*dy*dz Which is the definition of a mathematical way to calculate the volume respectively the surface, no ? -- Good luck Ivar
Posted: 1 decade ago 2015/02/14 0:08 JST
Okay, this question is old, but I haven't found any answers on the net yet. The way to do it is use the intop funciton but, don't select 1, but your boundary. Such as intop(T>300[K])
Posted: 1 decade ago 2015/02/15 1:20 JST
have you checked some of the ideas discussed here ?
www.comsol.eu/community/forums/general/thread/32577
And at some time, I believe there was an example of a volume estimation from the contour integral if the normal (Greens theorem) all linked to this example:
www.comsol.eu/model/hyperelastic-seal-206
Hi have you checked some of the ideas discussed here ? http://www.comsol.eu/community/forums/general/thread/32577 And at some time, I believe there was an example of a volume estimation from the contour integral if the normal (Greens theorem) all linked to this example: http://www.comsol.eu/model/hyperelastic-seal-206 -- Good luck Ivar
