IF OPERATOR
Posted 2011/10/03 8:59 GMT-4 Parameters, Variables, & Functions Version 4.2 1 Reply
I am solving the Helmholtz equation and I would like to use the IF operator such that when the dependent variable u > uref, then I specify the parameter c = 100 and when u < uref, c = 10.
Can I use IF(u>uo,100,10) when specifying the value of c? Because u is also a dependent variable, I am not sure if this is permitted in COMSOL.
To make it more simple, suppose that you are solving a heat transfer equation and you want to specify the thermal conductivity such that when the temperature is less than a certain value, you let the thermal conductivity be A and when it is greater, then the thermal conductivity is B.
Can anyone help with this?
Thanks.
Sincerely,
EH
Thanks.
Sincerely,
EH
1 Reply Last Post 2011/10/03 9:21 GMT-4
