How to use "Heat continuity"
Posted 2011/10/25 11:39 GMT-4 Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.1, Version 4.2 2 Replies
Hi everyone,
I am trying to understand what are the uses of the "Heat Continuity" module in the heat transfer module.
My guess was that this should enable you to create a virtual contact between 2 element that are not touching.
I tried to achieve this with a couple of small calculations and got nothing.
You get a sub-node called "Thermal Insulation" and whatever you might add as a sub node does not behave as intended.
Does anyone here knows how to correctly use this node to achieve continuity? Anyone has a sample code that might shed light on the use of this node?
Thanks in advance
Thanks in advance
2 Replies Last Post 2011/10/26 10:18 GMT-4
