Thermal Stress and Heat transfer in an Assembly. Contact boundaries don't seem to work.
Posted 2019/06/20 3:37 GMT-4 Structural Mechanics Version 5.4 1 Reply
Dear All,
I wonder wether or not someone can help me with a simple problem. At least that is what I assume.
I am working on thermal stress in a cooled mold and wonder about the heat transfer when the molded part looses contact with the mold wall due to shrinkage.
Hence, I use an assembly in a simple geometry, which is a rectangular region representing the mold and a smaller rectangle within the larger one to represent the molded part.
The molded part is initially at 300°C and the mold at 130°C. I set-up everything with the appropriate boundary conditions and material parameters. As contact model I use the pnealty method and standard settings for the Pair thermal contact. In the Solid Mechanics Module I apply gravity for the molded part so when it shrinks due to cooling, it will "fall" on the mold wall where the contact boundary should detect the contact. In that way, at least that is what i thought, there is always a contact between molded part and mold wall. However, the molded part moves right through the contact boundary and also there is no heat transfer at all.
I really wonder what is happening there. I am not a solid mechanics specialist at all, but from my understandig I set-up everything correctly. Maybe there settings that I need to tweak or I really did something wrong in setting-up the problem.
So if any of you are working or worked on similar problems, maybe you can give me some advice. Anything you can tell me is greatly appreciated.
Best regards, André
PS: I attached the model file I am using. PPS: Also, before you ask. On advice of Henrik I already read the manual on the topic of contact modeling. Especially when it comes to meshing and choosing source and destination in the contact pair.
