Parameter estimation + Parametric sweep
Posted 2019/06/25 11:13 GMT-4 Electromagnetics, Low-Frequency Electromagnetics, Studies & Solvers Version 5.3a 0 Replies
I am trying to perform Parameter Estimation on a set of measured data. I am using a Stationary Solution to solve the Helmholtz Eq and a Parametric Sweep to vary the width of a wire. As you may be already thinking, I am notified that the Parameter Estimation and the Parametric Sweep modules are not compatible. How can I get around this?
Previously, before I had measured data, I included the parameter I would like to determine in the Parametric Sweep. Now that I have the data I would like to fit it. Most of the literature on parameter estimation uses Time Dependent solvers, not sure how it would work with others.
I am new to comsol so please forgive any naive remarks. Thanks for reading.
Hello Owen Medeiros
