Parametric sweep for initial angle in rotating mesh
Posted 2019/10/01 5:02 GMT-4 Electromagnetics, Low-Frequency Electromagnetics, Structural & Acoustics 2 Replies
Hello!
I was wondering, is it possible to do a parametric sweep for the initial angle of a rotating mesh in version 5.4? I have tried to make one but for some reason I end up getting the same results in the sweep for all angles, and the rotating domain remains in the same position for all angles when I look at the results. It is strange because if I insert just one initial angle and manually simulate for each value individually I get different results for different angles as one would expect. Is there any way to make it work as a parametric sweep as well?
Thank you in advance!
